IAT resistor modification
Old Nov 6, 2002 | 12:02 PM
boonacka's Avatar
Default IAT resistor modification
has anyone done that IAT resistor modification? is it safe? what are the gains?
Old Nov 6, 2002 | 12:09 PM
YodiBrodi's Avatar
Default Re: IAT resistor modification (boonacka)
'splain. cuz i have no clue what you're talking about.
Old Nov 6, 2002 | 12:27 PM
ElephantMan's Avatar
Default Re: IAT resistor modification (YodiBrodi)
hes talking about them ebay advanced timing kits. From what I heard, they dont do sheit but then again I could be wrong
Old Nov 6, 2002 | 12:35 PM
boonacka's Avatar
Default Re: IAT resistor modification (phatkato)
yeah thats where i saw it. its supposed to trick the ecu into thinking your intake temp is colder than it really is
Old Nov 6, 2002 | 12:40 PM
GimpyAccord's Avatar
... or you could learn how to chip your ECU and advance the timing tables ...
Old Nov 6, 2002 | 12:41 PM
Perfectionist's Avatar
By replacing the IAT sensor with a fixed value resistor, you are simulating intake air temp for that specific value of resistance that you use. In other words, if the ambient temps are high enough, you MAY get a minor gain. If they are lower, (since winter is coming in a lot of the country) you may get worse performance. Basically it's a resistor you get from Radio Shack, ( I don't recall the value). Go to clubrsx.com and search for "timing advance". You'll find a bucket-load of information regarding the mod.
baseball_aj
Honda Civic (2001 - 2005)
Jul 19, 2007 01:01 AM
xkrntamax
Nov 18, 2005 01:15 PM
crx1racing
May 27, 2005 04:57 PM
ApolloSpeed
May 5, 2005 12:45 PM
miguelsanroman
10
Aug 9, 2003 05:14 PM
