LOTS of PARTS FOR SALE!!!
Trying to clean up my Garage, Here is a list of what i have for sale. Msg. or Email me if you want pictures of the parts. All parts is located in Hawaiian Garden (So.Cal.)
E-mail: Sam@importlife.com
MOTORS:
H22 fully build long block $3500,OR $2200 for the block
-87mm RS Sleeves
-wiseco Pistons
-Eagle Rods
-Acl race Bearings
-ARP headbolts
-Cnc Ported Head
-Cnc Valve springs/retaine rs
-blueprint stage 3 Cams
Euro H23 VTEC motor W/B16a tranny $4000
-Supertech valve springs and retainers
-stage 3 blueprint cams
-evolution H2B kit
2007 civic SI swap $3200
-axle
-ecu
-shifterbox and cables
k20 sleeved block $2200
-89mm bore
-13:1 CR wisco piston
-Blueprint rods
B16a swap $2000
-ZERO miles rebuild on the block
-Hydro tranny
98 spec B18C ITR swap- $4100
-Int. & Ext. valves been replace with SS valves.
Gsr swap $2800
-ZERO mile rebuild
-ITR piston
Jdm GSR swap $3000
-ZERO mile rebuild
ITR piston
Sohc Vtec d16z6 swap-$sold
Sohc vx d15b swap-800
2.2 GSR stroker block $old
-13:1 comp Wisco pistons
-Blueprint sleeves
-Blueprint Rods
K24 turbo block $2200
-Blueprint sleeved
-wiseco coated pistons
-Blueprint rods
-can hold 1400 hp built by blueprint
Ls block 0 miles W/type r pistons $900
K20z1 bare blocks $100
K24 head $100
GSR bare block 85.5 JG sleeve $150
LS bare block 86mm RS sleeve $150
Blueprint 105mm stroker crank $1700
Toda D b series cams $600
Wiseco 13.1:1 81.5 pistons used $old
Ctr pistons used .40 over $80 a set
05 Rsx Ecu $old
05 Rsx engine harness $100
Koyo rad for k swap eg/dc $200
Aem twin fire and Aem coil packs $old
Tranny:
K20a2 LSD Trans $1300
96-00 auto civic Vtec Trans $350
B16a cable trans- $sold
MOTORS:
-87mm RS Sleeves
-wiseco Pistons
-Eagle Rods
-Acl race Bearings
-ARP headbolts
-Cnc Ported Head
-evolution H2B kit
-axle
-ecu
-89mm bore
-Blueprint rods
B16a swap $2000
-Hydro tranny
Gsr swap $2800
-ZERO mile rebuild
-ITR piston
Jdm GSR swap $3000
-ZERO mile rebuild
ITR piston
-Blueprint sleeves
-Blueprint Rods
-Blueprint sleeved
-Blueprint rods
K24 head $100
05 Rsx Ecu $old
Tranny:
Such a nice list of goodies here and I hate to see it get locked. So. please see rules below:
Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
Pics with username@ht.com and date.
Craftyvtec
Sep 18, 2001 08:08 AM
