torque mount too low on driver side
Old Jan 2, 2016 | 06:50 PM
raverx3m's Avatar
Default torque mount too low on driver side
I just installed my urethane filled mounts and according to service manual I need to position the lower torque mounts right in the middle of the opening.
but mine is already all the way up and still sits on the bottom of the mount opening. I cant figure out why its like that on driver side but ok on pass side
no accidents on the car. and all mounts are good and filled with urethane
Old Jan 3, 2016 | 04:25 AM
94CivicSi's Avatar
Default Re: torque mount too low on driver side
I'm not 100% sure I understand, but in my experiece, you can raise/lower the height of the stud on the AC compressor mount by tightening or loosening the drivers side motor mount bolts.
If yours are tight, maybe you've got a tear in the rubber potion of the DS mount that's attached to the body?
Old Jan 3, 2016 | 09:46 AM
raverx3m's Avatar
yea its already raised all the way up
like the top mounts are sagging but they are all good and urethane filled as well. it shouldn't be happenning
Mccormick009
Nov 3, 2014 04:45 PM
See Are X
Sep 8, 2008 05:52 AM
vlc92189
Mar 25, 2007 08:19 PM
getdrugtoday
Aug 28, 2005 04:26 PM
DeDonDeRosa
Feb 22, 2005 08:28 AM
