help
Does your CEL, S or D4 lamps work? They should come on momentarily when turning the key to II(ON) before start.
If they do, check over by the passenger kick panel and look for a two wire blue connector.
Turn ignition to I(OFF) and jumper the connector with a wire.
Turn ignition to II(ON) and watch for any blinking from the CEL/D4/S lamps.
If no codes, verify the underhood ECM memory fuse is not blown.
Record codes and post back here for further diagnostics.
Brittain
Dec 5, 2015 07:34 AM
