pulsing idle,also see it referred to as surging on 2000 ex...
Old Jan 1, 2016 | 09:28 PM
GordieH's Avatar
Icon5 pulsing idle,also see it referred to as surging on 2000 ex...
i have a 2000 civic ex VTEC 1.6L SOHC.
i have a pulsing idle. up and down and up...no accessories are on.
Old Jan 2, 2016 | 02:20 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: pulsing idle,also see it referred to as surging on 2000 ex...
Remove the intake piping and start the car. Use your finger to block the hole inside the TB for the IACV. Does it still pulsate? Get a smoke machine (or a friend who vapes), and smoke test your engine looking for vacuum leaks. Just to eliminate a faulty code reader, is your CEL on? Does it work?
Old Jan 2, 2016 | 08:49 AM
GordieH's Avatar
yes CEL works
Old Jan 2, 2016 | 09:32 AM
GordieH's Avatar
when i cover the
Old Jan 2, 2016 | 06:20 PM
NotARaCist's Avatar
Replace your IACV.
Old Jan 3, 2016 | 07:27 AM
Jimi Hondrix's Avatar
Or do it Scotty Kilmer style and puff a cheap cigar through the brake booster vacuum line with air intake hose temporarily sealed off. Better yet, smoke yourself an Arturo Fuente 8-5-8 Natural Lonsdale. I tried this with my Civic about six months ago and it works very well.. both the test and the Natural Lonsdale.
OP.. Also, remove and clean the throttle body. It was tough to concentrate through that ****-storm of words you jumbled together in you original post but, I didn't see where or if you mentioned cleaning the TB.
Old Jan 3, 2016 | 10:44 PM
GordieH's Avatar
Icon6 Re: pulsing idle,also see it referred to as surging on 2000 ex...
https://www.youtube.com/watch?v=zMok2y05jNE
sorry that you can't be bothered to read everything done to this point.
you're useless as a result. you can't even be bothered to read what was or wasn't done,but you suggest something.
thanks,but no thanks as you certainly are not much of a technician based on that alone.
try lawn dart advice or something. it's simpler and requires much less reading...i'm sure.
Old Jan 3, 2016 | 10:45 PM
GordieH's Avatar
Replace your IACV.
thank you as well.
Old Jan 4, 2016 | 06:21 AM
Former User's Avatar
Bleed the cooling system and adjust the idle speed. If the problem persists, test the ECT sensor and TPS.
Old Jan 7, 2016 | 09:42 AM
GordieH's Avatar
thank you as well.
Old Jan 7, 2016 | 10:21 AM
Did you forget to reconnect the IAT after unplugging?
Old Jan 8, 2016 | 05:49 PM
GordieH's Avatar
no.
Old Jan 12, 2016 | 09:30 AM
GordieH's Avatar
wondering about som
Old Jan 13, 2016 | 06:00 PM
GordieH's Avatar
found bad baloney.
elnoyl
11
Mar 19, 2017 11:53 AM
Michael McCann
Jan 18, 2015 11:45 AM
jp520
Jan 14, 2013 01:22 PM
obagain
Mar 29, 2009 05:56 PM
