crx si sunroof issues
Old Dec 30, 2015 | 03:44 PM
rsfire's Avatar
Default crx si sunroof issues
Hey, my 90 crx's sunroof doesn't fully work. It tilts up to first level but has never slid back until last week. It was raining real hard and my interior got really wet, I don't know if it was coincidence or not but the sunroof started working. It would usually slide all the way back first time, but sometimes i would need to hold it for awhile before it opened. Once I drove away from the coast and the rain it stopped working again. Just tilts up and closes normal every time.
Any ideas if it is the switch, or relay, or bad leads on the motor? I did take apart the switch and clean the leads, no difference. If the switch was bad do you think it would even tilt upward?
Old Dec 30, 2015 | 05:42 PM
acmoc's Avatar
Default Re: crx si sunroof issues
I bet you're missing a rubber stopper somewhere.
The ones that catch the sunroof to pull it out
Old Dec 30, 2015 | 08:48 PM
rsfire's Avatar
Ok I'll look into that. Do you know if the motor should make noise or anything if that's my issue? It makes noise when the sunroof tilts up, but then it's dead silent if i click it again or hold it down. The motor is for sure not even moving past the tilt point
Old Dec 31, 2015 | 05:14 AM
v4lu3s's Avatar
RTFM
Make sure it's properly cleaned and lubricated...
Old Dec 31, 2015 | 10:34 PM
acmoc's Avatar
Hmm, I'm not sure, I think if it jams, the motor shuts off.
Mine wouldn't move after the tilt too once, the rubber stpper fell out.
Old Jan 2, 2016 | 01:50 AM
Tyson's Avatar
Switch.
take it out, open it up, clean the contacts. Everything will work.
Old Jan 3, 2016 | 09:53 PM
rsfire's Avatar
Thanks acmoc, that does sound like my issue. Is that stopper hard to get to? I'll pull up a schematic of the sunroof and look for it, but your advice will probably be more helpful.
And Thanks Tyson, I already tried that, no luck. I figure if that maybe it wouldn't even tilt if the switch wasn't working.
Old Jan 4, 2016 | 06:26 AM
instrument's Avatar
its aa couple bolts all easily accessible
I removed mine to vaccuum out all the rust, it was scary
sunroof works great now though
Old Jan 4, 2016 | 08:08 AM
acmoc's Avatar
It's held on by a 8 mm nut at the end of the rail. towards the rear of the sunroof.
I remember buying mine at the dealer. But it was hard to find the part number.
I'll see if I can locate it.
There are two in front as well that catch the sunroof when closing.
Here you go, all the info you need is here
CRX Community Forum ? View topic - Help me get my sunroof working correctly
I found this too
88 91 Honda Civic CRX Replacement Sunroof Stops All Four Stops Included | eBay
Dr.Fixit
Sep 20, 2013 04:42 PM
rexracer626
Jul 23, 2010 12:16 PM
ef-hatchcrap
Mar 4, 2009 03:10 PM
SamN
Apr 26, 2007 04:45 PM
muskrat
Dec 5, 2002 08:13 AM
