Aftermarket Fog Light Switch Issues
Old Dec 27, 2015 | 10:02 PM
Vague's Avatar
Default Aftermarket Fog Light Switch Issues
Car Info:
97 Civic Coupe DX
I had bought the SpecD OEM Fog Lights, and after the installation the fog light switch is malfunctioning
When I push the switch to turn the fog lights on they come on but when I click the switch again they won't turn off until I turn the vehicle off (I have the switch powered to the accessories) also sometimes when the switch is in the off position the lights will still come on when the accessories come on does anyone have any ideas of why this is happening?
I use to have the same fog lights and wired them the same way with no issues like this but the last switch harness that was given had a black ground wire instead of blue like the one I have now not sure if that would be the cause or not.
Old Dec 27, 2015 | 10:05 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Aftermarket Fog Light Switch Issues
Cheap Taiwanese **** didn't work out of the box? Color me surprised. Also, why are you not properly wiring them in with the headlights?
Old Dec 27, 2015 | 10:52 PM
Vague's Avatar
What do you mean wiring them with the headlights?
Old Dec 27, 2015 | 10:58 PM
NotARaCist's Avatar
Wire them properly, behind the headlight relays. They should only be able to turn on when the headlights are on. They should not be able to be on with the headlights off.
Old Dec 27, 2015 | 11:31 PM
Vague's Avatar
I might try that see if that fixes the issue
Old Dec 28, 2015 | 05:34 AM
civic402lx's Avatar
I normally like to power it off from the parking light. Switch and fog only get power if parking light are turn ON.
Old Dec 28, 2015 | 07:40 AM
Former User's Avatar
Originally Posted by Vague
Car Info:
97 Civic Coupe DX
Did you follow the installation instructions that came with the lights?
Old Dec 29, 2015 | 06:22 PM
Vague's Avatar
The original instructions wanted me to power the switch through my ignition and I don't wish to do that, so I just powered them through my accessories fuse opening, I use to have the same fog lights and hooked them up the same way but it doesn't wanna work right this time
Old Dec 29, 2015 | 06:36 PM
Rewire as per instructions.
Old Dec 30, 2015 | 10:42 PM
Vague's Avatar
Tapping the wire to my ignition will give it the same result, it still gives power to the switch when the ignition is activated
Old Dec 30, 2015 | 10:45 PM
Vague's Avatar
Default Wiring Fog Light Switch To Headlight Switch?
Car Info: 1997 Civic DX Coupe D16y7
Does anyone know how to wire a aftermarket fog light switch to the headlight switch? Basically what I'm trying to do is when I turn the headlights on it will then power the switch for the fog lights, but if the headlights are of the switch can't be used (No power)
Old Dec 31, 2015 | 12:58 AM
NotARaCist's Avatar
Default Re: Wiring Fog Light Switch To Headlight Switch?
Why do you need two threads for the same thing?
Old Dec 31, 2015 | 04:11 AM
hondur's Avatar
Dur Da Dur
5 Year Member
I prefer fog lights seperate from bead lights. Allows a sort of running light type of deal
Old Dec 31, 2015 | 07:59 AM
Threads merged.
My97CX
Mar 8, 2013 04:55 PM
Delano Devine
Honda Civic (2001 - 2005)
Mar 21, 2009 07:41 PM
PokeyD16Z
Jan 20, 2005 03:18 PM
bigedx
Jan 1, 2004 02:01 PM
str8edgexx
14
Aug 29, 2002 07:30 PM
