Rebuild idles at 1500, and sticks when driving.
Old Dec 26, 2015 | 01:42 PM
PeterVSays's Avatar
Default Rebuild idles at 1500, and sticks when driving.
I just did a swap and I transferred everything over except the usdm oil pump because we bypassed it. I let the car run for about 30mins and it stays at 1500 idling. I drove it around the corner and in between each shifts it stays at the rpm where I shifted at. Once in a while after releasing the clutch it drops and sometimes it stays at high rpms with no feet on throttle. What could be the issue? Sorry if I don't make sense. I'm really frustrated right now.
Old Dec 26, 2015 | 02:28 PM
1223's Avatar
5 Year Member
Default Re: Rebuild idles at 1500, and sticks when driving.
High or erratic idle is often tied to vacuum leaks. Review the lines you touched during the swap.
Old Dec 26, 2015 | 02:54 PM
PeterVSays's Avatar
I have a video that I'll have to upload later.
Old Dec 26, 2015 | 05:29 PM
PeterVSays's Avatar
Here's the video.
https://youtu.be/gdw76ma0LGU
Old Dec 26, 2015 | 07:27 PM
coolhandluke's Avatar
I would start with:
-Verify the throttle cable tension.
-Inspect the throttle body. Clean and confirm there are no sticking points.
Old Dec 27, 2015 | 07:08 PM
PeterVSays's Avatar
Originally Posted by coolhandluke
I would start with:
Fixed it yesterday. It was the TPS wire.
BIGef
May 4, 2012 12:16 AM
cdmef
Jul 3, 2011 06:03 AM
supracrx
Jan 7, 2007 08:06 PM
1ludeEK
Apr 10, 2005 05:39 PM
HATCHFREEK
Jun 13, 2003 12:47 PM
