gsr head
Old Dec 24, 2015 | 07:41 AM
teejdm863's Avatar
Default gsr head
How to adjust gsr head to put on ls block all valves are closed is it normal like that or what do I have to do?
Old Dec 28, 2015 | 03:40 AM
ej8's Avatar
ej8
Default Re: gsr head
Put head and block at TDC, don't install with them out of time.
Old Dec 28, 2015 | 07:32 AM
teejdm863's Avatar
Ok once I put both at TDC the head is good to put on , the valves should be good? Just askin cause my valves are all closed.
Old Dec 28, 2015 | 07:58 AM
ej8's Avatar
ej8
If cams are installed and all 16 valves are closed when #1 is at TDC then it sounds like the valve clearances are way too loose. Be sure to check all of them anyways as it is very important.
I highly recommend getting a factory service manual (helm) so you can follow Honda factory procedure on everything you do.
Old Dec 28, 2015 | 08:31 AM
teejdm863's Avatar
Ok thank u very much
milanoitr
Dec 9, 2011 04:18 PM
CRXREFIC
Nov 29, 2009 08:59 PM
xwhitchx
Mar 26, 2009 02:17 PM
AntMan401
Mar 17, 2008 02:13 PM
Ignitecivic
Sep 24, 2003 09:25 PM
