Clutch master cylinder
Old Dec 23, 2015 | 01:36 PM
globy123's Avatar
Default Clutch master cylinder
Hi. I have a 99 Honda civic LX and the master clutch cylinder is leaking fluid (pic attached). How do I fix the leak on the clutch master cylinder? What parts do I need to replace?
Old Dec 23, 2015 | 01:38 PM
97DXHatchback's Avatar
Default Re: Clutch master cylinder
i would just replace it its not too hard, 3 12mm bolts to remove it off the clutch petal itself, then a 10mm i believe for the line at the top of the master in the engine bay and then the hose and it should just pull out, i saw one at my local auto parts store for like 30$ then you just gotta re bleed the system
Old Dec 23, 2015 | 02:37 PM
globy123's Avatar
Should I replace the slave clutch cylinder at the same time I replace the master clutch cylinder?
Old Dec 23, 2015 | 03:24 PM
yessir i would , i got mine for 15$ with a lifetime warranty
Old Dec 23, 2015 | 03:54 PM
cvcrcr99's Avatar
replace both master and slave cylinders. bleed the system once and have it all done under $30.
gooblinn258
Jan 18, 2014 05:02 PM
R81_DC2
Aug 14, 2009 08:54 PM
97tegGS
Jun 10, 2005 05:13 AM
TurblowR
Mar 28, 2005 06:26 PM
