Need help with clutch replacement!!
Old Dec 19, 2015 | 02:39 PM
grampswrx's Avatar
10 Year Member
Default Need help with clutch replacement!!
OK, so I have been working on replacing the clutch on my 90 Si. The car is super clean and has low miles. I am replacing the clutch and flywheel and rear main seal with oem stuff.
Here is my problem:
I can't get the axles out. I tried busting off the ball joints with a big hammer, but that didnt work. So then I read everyone talking about how you dont have to remove the ball joint just the LCA and sway bar, then everything swings out of the way, the axle slides out like butter and Bob's your uncle.
I undid the LCA and the sway, but nothing "swings out of the way", at least not enough to get the axle out.
So i need some ideas. I have been going at this for about 4 hours and its starting to grate on me. I'm not a complete idiot, I have air tools etc.
Please help!
Here are some pics of where I am at:
LCA disconnected
Sway disconnected
Axle, popped out a little.
Old Dec 19, 2015 | 03:59 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Need help with clutch replacement!!
Your lower control arm looks like its still bolted in from that last picture.
Old Dec 19, 2015 | 04:00 PM
grampswrx's Avatar
10 Year Member
So you remove the lca completely? That makes a lot more sense. Let me go try that.
Old Dec 19, 2015 | 06:58 PM
acmoc's Avatar
You're doing it way wrong.
Remove the lower control arm from the hub
Use this
Old Dec 19, 2015 | 07:08 PM
grampswrx's Avatar
10 Year Member
What am I looking at? Is that a ball joint extractor thing?
Old Dec 19, 2015 | 07:27 PM
Bently_Coop's Avatar
Steve at Heart
You need a pitman arm puller and pop the lower ball joint loose.
Old Dec 19, 2015 | 08:00 PM
grampswrx's Avatar
10 Year Member
I was under the understanding that you could remove the axles without popping the ball joint. Is that not the case?
Old Dec 19, 2015 | 08:19 PM
24TEN's Avatar
PHANTOM MENACE
You can. That's the course you're on right now. Personally I'd still say just pop the balljoint out. There are ways to do it without that tool too. What were you trying to smack it with earlier?
My way of popping the balljoint out is to jack the LCA up until you have enough room to wedge a breaker bar in between the LCA and the knuckle where the balljoint meets. Slowly lower the assembly down until it pinches the breaker bar and release the jack completely. Might take a few tries but it's never let me down. For the record though I find it much easier to just smack the arm with my 5lb sledge. 2 hits is usually all it takes.
Old Dec 19, 2015 | 08:35 PM
acmoc's Avatar
How would you remove the axle without unbolting it from the hub?
You're just trying to move it out of he way?
Old Dec 19, 2015 | 08:43 PM
grampswrx's Avatar
10 Year Member
I've been hitting it with a 2 pound plastic sledge.
The axle nut is already off. I'm trying to get the hub out of the way to take the axle out.
Old Dec 19, 2015 | 08:53 PM
grampswrx's Avatar
10 Year Member
If I'm hitting it with the hammer, should I hit it upward? Rearward? Forward?
Old Dec 19, 2015 | 10:28 PM
24TEN's Avatar
PHANTOM MENACE
You should be hitting the arm itself. Look for a flat spot around the area where the balljoint gets inserted. Don't be afraid to hit it with a good amount of force.
Old Dec 19, 2015 | 10:30 PM
grampswrx's Avatar
10 Year Member
I gave up on the arm. Took off the other LCA bolt and it dropped right out of the way. Axles are out!
Now, i just have to do the rest of everything else.
Seriously, guys, thanks for your help. I was ready to throw in the towel. Now I will just rest until tomorrow, when I will probably want to throw in the towel again.
Old Dec 19, 2015 | 10:40 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
If you disconnected the lca, and move the shock out the way, youd be able to use the hub as a axle puller, and when its time to put the axle back in, just push on the hub til the axle goes back in.. Good for people who dont habe the 32mm or 36mm socket
Old Dec 19, 2015 | 10:58 PM
raymondpowens's Avatar
disconnecting the LCA does help, but also removing the fork from the shock (just a single 14mm bolt) makes a big difference. that fork is where most of the obstruction and clearance issues are. plus then you dont have to remove the ball joints.
Old Dec 20, 2015 | 04:51 PM
Ef4doorwagon's Avatar
I bought a lower ball joint remover from harbor freights, like 20$. It removes the lower ball joint and tie rod ends in seconds.
killa31
18
Oct 18, 2017 01:49 PM
pit.crew
Mar 16, 2012 10:35 AM
David12
13
Oct 9, 2009 08:46 PM
namewasdallas
Jun 11, 2009 11:56 PM
CRX2NV
Jun 5, 2003 12:48 PM
