syncros for 1st gen b16a tranny?
I'm buying a 90 civic hatch from a buddy with a b16a swap in it but the tranny grinds into 2nd and 3rd when you shift hard so the syncros are going out. Can I go down to a Honda dealer and get syncros or are they hard to source for these trannies?
I don't remember what tranny he used but I know the swap had a pr3 ecu so it's an integra XSi tranny.
try replacing the MTF first.
just because the swap came with a certain ECU, it doesn't necessarily mean that the motor, trans, and ecu all came off of the same type of car. If the trans is off of an XSi, then it probably has the S1 trans. You can tell what kind of car the motor came off of if you check the stamp on the engine block. there is a serial number underneath the "B16A" engine code. If it starts with a 1, then it came of an Integra XSi or RSi. If it starts with a 5, then it came off of a SiR Civic or CR-X. And yes, you have to get JDM synchros. I don't even think that you can go to Acura and a order synchros for the 92-93 GS-R (YS1).
OK then do you know where I can get a JDM syncro kit?
[Modified by CR-X, 7:40 PM 11/7/2002]
OK then do you know where I can get a JDM syncro kit? There is a kid on here that can sell you them?
I think his user name is JDM_DOHC_SiR
Kid
maybe at heart
not that young any more hahahaha
I can land them for you ... But I wont be back in Japan to get the kits untill the end of December
What comes with the y1 kit. Syncros only? What about the gear sets and all the bearings? I am also interested.
Say around 600$ not worth it. besides more than 90% of the time the only thing that is Jacked up in the Y1/J1/S1 trannys are the snycro rings between 3~4th gear.... I re~built about 7 of them and they all have the same wear patterns...and these cars have less than 60000kms on them.Anyway the "Syncro Kit" only comes with syncros for that price..
Kid
maybe at heart
maybe at heart
honda mtf is 10-W-30
"Rocky road? huh huh."
Trust me, its not straight 10-30, just smell it, it smells just like Gear oil.
Jeff
sweetbai00000
Mar 27, 2007 09:23 PM
Creator
Oct 26, 2004 07:11 PM
xtremcrx77
Jan 1, 2002 05:13 PM
