Water leak 90 crx
Old Dec 17, 2015 | 02:44 PM
rsfire's Avatar
Default Water leak 90 crx
Hey this may be a stupid question. But I'm on the coast and it's raining hard. My floors keep pooling up water and I have yet to track down the leak. The passenger floor board and behind both seats pool up bad. Before I get home and tear out the carpets, has anyone had this issue and know where I might start the search? Thanks
Old Dec 17, 2015 | 05:06 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Water leak 90 crx
Do you have a sunroof? Common issue is the drain tubes getting plugged.
Old Dec 17, 2015 | 06:54 PM
acmoc's Avatar
Yep, drain tubes are located behind the tail lights.
Pull 'em out and see.They have a little nipple at the end and slide into a slot that exits to the rear fender well area.
Old Dec 17, 2015 | 08:38 PM
bigtimegambler's Avatar
For the passenger floor board leak; windshield and/or wiper cowl could have a bad seal. The epoxy will crack and shrink when weathered.
Old Dec 17, 2015 | 10:12 PM
acmoc's Avatar
Is it water?
No Antifreeze?
Could be a leaking heatercore
Old Dec 20, 2015 | 06:34 PM
rsfire's Avatar
Awesome! I will check out my drain tubes. I haven't had enough time after work to fix it. It's just water, it's been raining very hard here. I don't know if it could be windshield or wiper cowl since water is all the way behind the rear seat
thewrai6th
Feb 17, 2017 09:50 AM
dc2teg808
Mar 14, 2009 12:38 AM
crxforum
Oct 30, 2006 01:15 PM
effinnwackk
10
Jul 15, 2005 05:31 AM
hOndafienD 04
Dec 9, 2004 11:13 AM
