2000 Honda Accord EX 4cyl Distributor
Old Dec 15, 2015 | 09:20 PM
bill75's Avatar
Default 2000 Honda Accord EX 4cyl Distributor
I have a 2000 Honda accord EX (4Cyl) with an oil leak from the side of the distributor. I looked at previous posts and the recommendation is to change the O ring and the inner seal, if it needs it. My question is if changed the distributor with a new one does the timing needs to be a adjusted.
Old Dec 17, 2015 | 04:08 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 2000 Honda Accord EX 4cyl Distributor
Shouldn't. '96-02 OBDII distributor top bolt hole is not slotted and does not allow any adjustment. Verify the rotor is pointing in the same direction as the old one before removal.
Unbolt old, bolt on new.
micekmike
Oct 30, 2017 06:33 PM
ZillaG
Apr 6, 2016 02:56 PM
lufth
Nov 14, 2013 12:38 AM
