My 96 spec ITR swapped CRX
Old Dec 12, 2015 | 11:50 AM
Serdar's Avatar
Default My 96 spec ITR swapped CRX
Got the swap from hmotors at the beginning of the year.
Replaced dizzy cap,rotor,waterpump,tensioner,usdm oilpump all from Acura, along with gates racing timing belt. ngk iridium plugs and blue wires.
Had the factory 240cc ITR injectors cleaned.
swapped it into my 91 CRX si.
Heres the setup:
96 spec jdm ITR b18c, LSD 4.4fd
3inch SRI(hot air) with blox vstack
1320 toda rep header 2.5in collector and 2.5inch testpipe to
Buddy club spec II bpipe only (2 inch piping, choking i know)
Blox fpr
Exedy stage 1 clutch/pp
Chipped p28 w/ crome
The car put down 191/133 in july heat tuned by dan @ japdata in tampa,fl.
Took it to the track in August ran a best of 13.478@103.75 on all season 195/50-15 tires. car 3780
Got a passenger headlight with hole cut in it from a good friend. Mocked up and made a 3 inch intake out the headlight with my 3in blox v stack with (3) intake pipes and couplers i had laying around.
Took it to the track in lastnight ran a best of 13.235@106.98 on same all season 195/50-15 tires. car 3780
Old Dec 12, 2015 | 01:39 PM
Twin Cam's Avatar
Default Re: My 96 spec ITR swapped CRX
Impressive times!
Old Dec 12, 2015 | 03:29 PM
ryanplayjoint's Avatar
Kick *** car. Do you know the weight of the Rex?
Old Dec 12, 2015 | 03:58 PM
vtecmaster85's Avatar
Good stuff man!!
Old Dec 12, 2015 | 04:50 PM
PyroProblem's Avatar
Nice times and good numbers. Especially in that Florida heat! Slicks and 12s easy.
Nice job.
Old Dec 13, 2015 | 04:57 AM
Serdar's Avatar
Originally Posted by Twin Cam
Impressive times!
Originally Posted by vtecmaster85
Good stuff man!!
Nice job.
Thanks guys! I purchase Hondata s300v3 from xenocron earlier this month, Ill be retuning in january hopefully I can make over 200whp. I will eventually get around to acquiring 22" slicks.
Thanks again, Crx Si weighs 1,920lbs without me and 2,180lbs with me in driverseat.
Old Dec 14, 2015 | 09:45 AM
AllMtrRex's Avatar
Respectable times for stock long block.
You picked up nearly ~3 mph between the two slips. Did you do some weight reduction
between these runs or just the intake out the headlight?
Old Dec 14, 2015 | 09:36 PM
Bently_Coop's Avatar
Steve at Heart
Very nice. Have you looked at mounting the battery on the frame rail?
Old Dec 15, 2015 | 06:25 AM
hondatuner020's Avatar
Nice job fellow 96 spec ITR CRX brother!
Old Dec 15, 2015 | 03:46 PM
Serdar's Avatar
Thanks!
The only things I removed between this time is radio, (2) 5"3/4 door speakers, passenger door panel. I also replaced the rear lower control arms with billet alum ones. Got my factory injectors cleaned, and added the 3" intake out the passenger headlight. I swear when i was running the short ram intake i felt as if i was heatsoaked after a couple pulls.
Well Im leaning more towards interior possibly passenger footwell near the ecu tucked up under the dash, thats actually one of my next projects!
thanks bro! Im eyeing this 88 si parked up in the neighborhood across from me, no tag, just need to find the owner and make a deal lol
Old Dec 15, 2015 | 05:27 PM
JDMGSRCRX's Avatar
Nice to see another CRX running the '96 ITR motor!
I put down 211whp/147tq on a dynapack here in cali. Same exhaust, tuned on Hondata S300 at Ericks Racing. Rebuilt from the bottom up, left mainly stock except .5 size over JDM RS ITR spec pistons.
What header are you running? I've been having clearance issues, first with an ITR replica header that came with the motor, and now with my Skunk2 megapower header. Looking to get the V2 hoping itll have better clearance. My driveway sucks *****....
Old Dec 15, 2015 | 09:26 PM
93egSLEEPER's Avatar
If you want better clearance try a 4-1 header. My personal favorites on 1.8's are the Toda rep (not 4-1) and RMF narrow. Fit nice and snug.
Old Dec 16, 2015 | 01:42 PM
Serdar's Avatar
Thats good power 211whp/147wtq, is it running factory I/M and TB? I recently purchased hondata s300v3 just need to install into ecu. Im running the 1320 toda replica header 4-2-1 style with 2.5 inch collector to 2.5 inch testpipe to buddyclub spec II b pipe. The buddyclub is about 1.9-2in diameter piping i feel like I can gain power from a 2.5in upgrade.
My car isnt very low, although the toda rep im running has good ground clearance.
Old Mar 19, 2016 | 11:02 PM
Serdar's Avatar
BUMP/UPDATE new personal best 13.1@106 on 195/50/15 Toyo r888(18psi) no other changes
Old Mar 20, 2016 | 09:13 AM
h23bb2's Avatar
Very nice! Super jelly of the LSD. Its definitely working for you with those 60' times!!
Old Sep 9, 2016 | 05:20 PM
Serdar's Avatar
Bump/UPDATE: Recently Installed Skunk2 Stage 1 Cams/Cam gears, cams degreed, Skunk2 LMAs, Blox 68mm TB portmatched to stock IM, Hondata IM gasket, RDX injectors, Walbro 255, AEM fpr, 2.5 inch race muffler 2.5inch crushbend exhaust, PLX wideband and Hondata s300v3.
Tuned by Derf on 9/8/2016 at STP motorsports @ plantation,fl.
Made 213whp/143wtq.
Gained roughly 23whp and 10wtq from above upgrades, to say the least im very impressed from this stock block 1.8L on 93 pump!
Old Sep 9, 2016 | 06:12 PM
sr20paisa's Avatar
12's are on the way!
Old Sep 9, 2016 | 07:25 PM
Serdar's Avatar
Bruh I would be so freakin happy with a 12.99 on these r888!
Old Sep 10, 2016 | 05:07 AM
Congratulations on the successes. You are driving the hell out of the car! Can you share your short track driving technique? Burnout? Launch rpm? Full throttle/lift shifting, pre-loading?
Old Sep 11, 2016 | 10:43 AM
Serdar's Avatar
Toyo R888 air'd down to about 18psi. No burnout i drive around the water, pull up to first light, ebrake up ease the clutch out and etch to second light is lit hold 3500 to 3800 rpm. Release clutch and go wot on green, shift on shiftlight (8000).
Old Sep 12, 2016 | 08:30 AM
Thanks for sharing. We have similar setups less the driving ability and tire (bfg rival s). I'm having difficulty getting time out of my setup.
Old Sep 12, 2016 | 08:46 AM
Looking real good. This was the route i planned to go N/A before i decided to get back into boost. Glad its going very well for you!
FULLYBUILT2.0
Mar 7, 2011 09:23 PM
toolbox21
Jan 16, 2010 04:59 PM
Spoon84
Jul 7, 2009 06:16 AM
Dougie Pants
Feb 13, 2005 06:19 PM
