Honda CR-V & Element 2WD & 4WD Element & CR-V
Dead CRV
Old Dec 10, 2015 | 03:52 PM
cgteacher's Avatar
Default Dead CRV
Sorry if I am posting this in the wrong place but I am at wits end with this car.
97 CRV Automatic AWD
no spark
no fuel
printed wiring diagram and test continuity across ignition switch
passed
Pulled main relay and bench tested passed Can also hear relay click in dash with key.
tried to get codes from ECU could not pull anything with scan tool, tried jumping connector and CEL stays on so figured code 0.
bought used ecu still no go
have checked and cleaned grounds
Timing belt is still intact as dizzy is still spinning.
I am out of ideas
Old Dec 10, 2015 | 08:23 PM
EJ8_Man's Avatar
Default Re: Dead CRV
And you checked all the fuses under the dash and under the hood?
Old Dec 11, 2015 | 03:38 AM
cgteacher's Avatar
Checked the fuses as well
I'm down to chasing wires as my next plan of attack
503_EF9
Sep 11, 2009 06:51 PM
aarontrini85
12
Jun 29, 2007 08:28 AM
Speedyjay
Apr 28, 2007 05:29 PM
Pandahatch
Feb 5, 2004 06:16 PM
