adjustable test pipe flange bigger than header flange
any way to get this to work? im not looking to weld.
the flange part of the adjustable test pipe is bigger then the header flange part. bolt holes are way off.
can take pic if needed
You will need a reducer piece to go from one flange to the other. Or you might be able to hone out the flange bolt holes to allow for them to bolt up.
This is kind of a vague question. If you post up pictures of the two flanges you might get a more accurate answer.
Could you at least list what size and style flanges you are talking about here?
This is a thread of the blind leading the blind!
not at home but this is the header
Acura Integra RS GS LS 4 2 1 B18A1 Stainless Steel Chrome Exhaust Race Header | eBay
test pipe
http://www.ebay.com/itm/94-01-INTEGR...BV3nW8&vxp=mtr
test pipe
Yeah! 1/2" diameter difference is a bit much for a non weld solution.
Just out of curiosity what diameter is the rest of your exhuast?
back part bolts up fine to my exhaust. the doughnut for the front mates up fine to the header.
its just the holes for the bolts which is why i was asking if i can cut this bigger flange off and clamp on a smaller one.
if so where can i find this?
The flange on the header is stock sized and the flange on the test pipe is much larger. You could buy a2.25" ball flange and 2.25 to 2.5 adapter then cut your test pipe up and weld. Or just go buy the 2.25 inch test pipe.
