98 civic ex idle problem
Old Dec 9, 2015 | 09:02 PM
frankgk's Avatar
Default 98 civic ex idle problem
I have a 98 civic ex... I replaced the IACV, TPS, fuel filter, distributer cap/rotor, thermostat, battery cable ends and spark plug wires.... When i start the car it starts fine idles at about 1,000 rpms but after the motor warms up the rpms fluctuate between 1,500-1,600... What could this be?
Old Dec 10, 2015 | 07:47 AM
Former User's Avatar
Default Re: 98 civic ex idle problem
Post all CEL codes that are thrown.
Is the hunting idle a long term or recent problem? Give some background.
Did you bleed the cooling system properly?
Old Dec 10, 2015 | 09:56 AM
frankgk's Avatar
The only CEL code i got was p0505
This started about 1 month ago i figured it just needed a tune up, so i gave it a tune up minus the spark plugs... So then i put the TPS on it and then the check engine light came on, i pulled the code got P0505 replaced the IACV and the light came on again with the same code.. So to answer your question it's been acting like that for about a month now
And no i didnt even bleed it because i'm getting new radiator hoses and clamps
Davenflorida
15
Aug 10, 2015 05:40 PM
jibs
Jun 5, 2012 04:44 PM
Max McNasty
10
Dec 11, 2008 08:29 PM
jwicecold
Mar 29, 2006 09:47 AM
CPL
Aug 24, 2004 05:41 PM
