Stock valve spring pressure b16a?
The #1 result when searching for "Valve Spring Pressure B16" on Google. Seriously.
If you can manage, click your left mouse button on these underlined words below.
Discussion about valve spring requirement - Team Integra Forums - Team Integra
or this is the b16a ??
Acura USDM/JDM GSR INTAKE SIDE oNLY Valve Springs
Variable or Linear: Linear
Seat Pressure: 50lbs
Max Lift: 11.5mm
Coil Bind: 11.7mm
Pressure @ 11.5mm/.453" lift: 150lbs
As noted on that thread...
"A list of common valve spring specs for different manufactures. This is for B18C1, B18C5 & B16A Heads."
These figures apply to all three Vtec B series heads.
OBD1EK
Jan 8, 2003 04:55 PM
