05 RSX no heater..
Old Dec 8, 2015 | 06:36 PM
Jonathan Cortez's Avatar
Default 05 RSX no heater..
So I was told to drain and possibly replace the thermostat, I did, but all I get is cold. I was told it might be my gauges that for whatever reason it's reading cold if that makes any sense. Any suggestions of what it might be?
Old Dec 10, 2015 | 06:04 PM
Hughie1987's Avatar
Default Re: 05 RSX no heater..
blocked heater core is my thinking, like are you actually only getting cold air when the heat is on or are the gauges showing cold when you have hot air?
Old Dec 12, 2015 | 07:36 PM
I'm just getting cold air when the heat is on
Old Dec 14, 2015 | 11:46 AM
ShinsenTuner's Avatar
No Jodas
You need to bleed it more, probably a bubble in the system or low coolant.
Old Dec 16, 2015 | 08:41 PM
InTheZoneAC's Avatar
with the car cool check your radiator, the coolant should be maxed out. if it is low, this is a reason why your air is cold
Also, if your radiator is low, go ahead and completely top off the overfill tank as when the car cools down the air will vent out and will draw coolant from this tank.
Basically when you squeeze the radiator hoses, they should feel pretty solid when your car is cool. They should not be easily compressed as that's another indicator you still have air in the system.
There is no reason for your heater core to be blocked. Have you done any work on it lately? Any coolant leaks? Can you see if the heater core valve is opening when you turn the dial from cold to hot(air doesn't have to be blowing). It should be near the firewall somewhere, haven't looked for it on my rsx, but on the civic it's on passenger firewall. Basically you want to see the little servo or whatever it is, the heater arm will rotate as you turn the dial.
Wrona
Nov 6, 2011 02:26 PM
kelviiv
Jan 25, 2008 01:55 AM
fast+forward
Jan 29, 2007 03:13 PM
eurodeseo
Jul 4, 2006 06:55 PM
ex_crxer
Apr 6, 2003 06:52 AM
