(2000 Civic GX) Low pitch hum/rattle, vibrating brake pedal when riding over pothole
Hi all,
I could use help diagnosing an issue on my 2000 Civic GX (84,000 miles, no modifications except for rear and front sway bars)
If I brake while riding over a pothole, or a large dip, I feel a loose/rattle feeling from the brake pedal, and I hear what sounds like a low pitched hum/jostle/rattle -- all of this may be at oscillating frequency (not totally sure yet)
Some more details on my reproduce-able cases:
* Pot hole test involves depressing brake petal before I enter the pothole/dip, and I keep it pressed. I performed this for speeds starting from 20-35mph
* My pothole test involved me braking while riding over a pothole with my passenger side front tire. Firm, moderate, medium-light braking doesn't matter - I still hear the noises and feel the sensation through brake pedal.
* Dip test involved my driveway - I entered driveway braking from a speed of ~15mph.
Mentioning in case it's related -- I've been noticing another rubbing noise in morning when I pull my car out of driveway. I turn the steering wheel far right as I back out, and I hear the rubbing noise as I go forward and my steering wheel straightens back out. Rub is also lower pitched hum noise -- but not a rattle.
any tips on root cause most appreciated.
Thanks.
__________________
Thanks.
__________________
Sounds like your ABS is kicking in. This is normal. Have you ever locked up your wheels in the rain/snow? This should be the same pedal feel. It should feel like the brake pedal is pulsing under your foot very rapidly and you should hear a pulsing/clicking noise that corresponds to the pedal.
This happens to me all the time in my Fit when driving over poorly installed manhole covers.
Ahhh I see. Thanks for responding.
Is this level of vibration/sound specific to Civic/Fit? I've driven dozens of cars over past 18 years, and this is first time I've heard this noise and feel in the pedal whlie braking.
I wonder if its the caliper pins? I have a similar noise I've been trying to diagnose on my brother's 2002 civic that doesn't have ABS. I plan on replacing the pins and seeing what happens on it.
Does braking performance feel affected? I thought mine were bad strut bearings at first with the noises I was getting.
Mark Floyd
Dec 2, 2015 09:08 AM
c 2
Jan 29, 2008 07:06 PM
