F20C crank on a f22C stock block
I believe the only difference mechanically between the 2 are the crank,rods,and pistons. That being said, you should be able to swap the entire reciprocating assembly into the f22c block.
The crankshaft must match the rods. F22 crank with f22 rods. F20 crank with f20 rods.
Check out the s2000 section as well. From what little I know about s2000's, your idea should work.
If the compression height of the pistons are the same, it should work. What the compression ratio will be, I don't know. I would think f22c pistons would lower your compression vs the f20c pistons since more stroke with same dome volume increases compression.
Would i still be able to rev. To 9k with this setup?????!
Dimensionally, the F20C and F22C blocks are the same. So, using a F20C crank, F20C rods, and F20C pistons in a F22C block makes a F20C engine (with an F22C stamp on the block). It will act just like a F20C engine. Using the F22C pistons will yield slightly LESS compression due to a slightly smaller dome volume and shorter install/compression height.
Jason Helton
Mar 12, 2018 06:34 PM
GT500FTW
Dec 18, 2012 11:59 AM
