Ls vtec motor
Semi built lsv longblock. Please text for faster response! 9206526467
Will now part if anyone is interested in the head or block!!
Ls vtec build
* = new
Ctr head (rebuilt, valve job, hot tanked, resurfaced)
Skunk2 pro 2 cams (slightly used)
Skunk2 pro series cam gears (slightly used)
Rocket motor sports SL dual valve springs*
Oem K20a2 retainers*
Vtec solenoid w/new gasket
Obd2 dizzy
Oem usdm itr valve cover*
B18b1 block (bored, honed, slightly decked, cleaned and painted)
81.5mm rs machine pr3 pistons w/new piston rings*
Reconditioned ls rods (shot peened, balanced)
Polished ls crankshaft
Moroso 4qt oil pan*
Hondahabit oil pan gasket*
Oem vtec head gasket*
Arp rod bolts*
Arp head studs (torqued once)
Oem p72 timing belt*
Oem p72 water/oil pump*
New tensioner*
Oem honda main/rod bearings*
Oem breather box*
Golden eagle lsvtec conversion*
Obd2 alternator
Alternator bracket
**cams were degreed +3.1ex , -1.1 int
Also have itr fuel rail w/new rc310cc injectors*
68mm throttle body (new tps sensor and gasket)
Iacv w/new gasket
Freshly resurfaced oem itr flywheel
Hydro b16 tranny
* = new
Obd2 dizzy
Moroso 4qt oil pan*
Arp rod bolts*
New tensioner*
Oem breather box*
Obd2 alternator
Alternator bracket
Iacv w/new gasket
Hydro b16 tranny
killerpenguin21
55
Aug 31, 2007 11:34 AM
