Knock sensor
Old Dec 2, 2015 | 04:42 PM
Kayronn Grier's Avatar
Default Knock sensor
So I did a rebuild on my Y8 an it turned out great. Im having a issue with my car idling at 2grand. I checked the map, tps, IAC and all vacuum hoses. Everything was fine. My car keeps throwing a code for the knock sensor. When I plug my OBD to the car an clear the code the idle calms down. But after a while the light come back on an starts to idle at 2grand. The curious to kno if a knock sensor can actually cause this issue. Here are a few pics from the build just to share with everyone.
Old Dec 2, 2015 | 08:21 PM
Jimi Hondrix's Avatar
Default Re: Knock sensor
Go to junkyard> pull knock sensor> pay $10 for it> install it and hope it fixes the idle issue... Doesn't seem like a part that would cause high idle but best to replace if it's causing a CEL. Read: http://www.ehow.com/facts_7680413_kn...-problems.html
Also, check the vacuum line that connects from the cruise control to the intake manifold... may have disconnected at the intake side. Congrats on your rebuild.
Old Dec 3, 2015 | 04:01 AM
Thank you I appreciate an yeah I got the sensor now. Ima change the oil an slap the sensor on an see what happens. Wish me luck.
Old Dec 3, 2015 | 05:25 AM
Ohmega's Avatar
D16Y8's do not have a knock sensor.
What ECU do you have? And post the actual CEL code please.
Car info as well.
Old Dec 3, 2015 | 06:08 AM
spAdam's Avatar
Loved
Community Favorite
Yeah, they do. Knock sensor is standard issue OBD2. It's in the usual location right above the oil filter.
OP, make sure to get one from another Y8. They are not all the same even if they look it.
Old Dec 3, 2015 | 06:24 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
The y7 dont have one.
Jordan Sharples
Honda Civic (2001 - 2005)
Jul 7, 2018 10:38 PM
ek coupe
May 20, 2009 09:45 AM
SpoonFedEj8
Dec 23, 2008 03:11 PM
stephenB!
Mar 12, 2004 06:33 AM
CandyRedHatch
May 5, 2003 08:31 AM
