can o damage my canister ?
Old Dec 2, 2015 | 03:12 PM
gabrielsousa's Avatar
Default can i damage my canister ?
Can i damage my canister ??
if i remove the marked green and blue tube, can i damage the canister ?
Old Dec 2, 2015 | 04:24 PM
4drEF's Avatar
Keyboard Humorist
Default Re: can o damage my canister ?
No, but the canister won't work if you do that.
Old Dec 2, 2015 | 09:10 PM
bigtimegambler's Avatar
lol, what exactly are you trying to accomplish by removing these hoses...
Old Dec 3, 2015 | 12:16 AM
the vapours will not accumulates on the canister ?
the gas tank will not breath ?
cleaning the engine bay
Old Dec 3, 2015 | 07:37 AM
What you need to do is the canister delete. Route the fumes hose down and out of the engine bay, unplug the solenoid, and plug up the holes on the intake manifold. There are specific guides on this forum for how to do this, step by step.
Old Dec 4, 2015 | 07:09 AM
4drEF's Avatar
Keyboard Humorist
If you just want to remove the hoses, don't both. you aren't gaining anything but becoming a polluter.
The vapour in that canister is usually very little and is drawn into your intake during acceleration. It actually helps gain mpg (very very little, but still) as well.
Your car isn't a show car. You rarely open your hood. The rest of your engine bay is dirty.
Just leave it alone.
Old Dec 4, 2015 | 04:05 PM
acmoc's Avatar
You can delete the canister competely.
It holds pressure vapors from the gas tank to burn later on.
Just remove the hoses and plug the lines to the engine
Leave the one that comes out the firewall(It vents the gas tank).
Tape up the electrical plug and save the parts, you might need them for emissions. You might, not like the gas smell or may not like the 1-2 drop in mpg.
I would just leave it.
Old Dec 5, 2015 | 09:31 AM
i dont want to remove the canister.
just wanna know if i remove the 2 tubes i marked with blue and green, will damage the canister .
or the canister will not receive the vapours ?
Old Dec 5, 2015 | 09:37 AM
If you don't remove the canister, you can't remove the hoses. Simple. We already told you the canister won't work without the hoses.
Old Dec 5, 2015 | 09:40 AM
ok ,thanks
Old Jun 20, 2016 | 09:32 AM
sorry for the late question, just one more, to understand
all you said that without the 2 hoses ( green and blue ) that the canister dont work.
what happens to gas tank vapours ?
Old Jun 21, 2016 | 12:36 PM
94eg!'s Avatar
#1 Super Guy
Loved
Everything everyone has said in this thread is wrong.
Removing those two hoses will not damage the canister. The canister will just over-flow eventually (especially when its hot out) and fumes will be vented out the bottom. The exact same thing happens if you remove the canister completely, so why waste your time?
The canister does not hold pressure whatsoever. It merely stores the fumes that get vented when the tank pressure gets over 2psi. When this happens, the 2-way valve opens and tank pressure drops to normal. The fumes are then supposed to get sucked into the motor. This reduces emissions and prevents your car from smelling like raw fuel.
hermistonkilla
Feb 3, 2010 09:28 AM
dkrex001
Sep 27, 2006 11:03 AM
clemsoncb7
Jun 7, 2005 03:35 AM
Chase
22
Mar 21, 2005 02:59 PM
gnar kill
Feb 28, 2005 10:47 PM
