Ls vtec motor
Old Dec 1, 2015 | 04:58 PM
vroomvroomjdm24's Avatar
Default Ls vtec motor
Testing to see if anyone would be interested in a semi built lsv motor. Please text for info since i dont have pics right now w/hondatech sign. 9206526467
Old Dec 2, 2015 | 12:26 PM
Default Re: Ls vtec motor
Old Dec 6, 2015 | 11:07 AM
jvtec95's Avatar
Can you add some info to this FS post? What parts are in it, what is new, asking price, etc?
Old Dec 6, 2015 | 09:08 PM
Sorry. Im not on here much anymore, thats why i said to text for faster response.
Old Dec 7, 2015 | 07:20 AM
Ls vtec build
* = new
Ctr head (rebuilt, valve job, hot tanked, resurfaced)
Skunk2 pro 2 cams (slightly used)
Skunk2 pro series cam gears (slightly used)
Rocket motor sports SL dual valve springs*
Oem K20a2 retainers*
Vtec solenoid w/new gasket
Obd2 dizzy
Oem usdm itr valve cover*
B18b1 block (bored, honed, slightly decked, cleaned and painted)
81.5mm rs machine pr3 pistons w/new piston rings*
Reconditioned ls rods (shot peened, balanced)
Polished ls crankshaft
Moroso 4qt oil pan*
Hondahabit oil pan gasket*
Oem vtec head gasket*
Arp rod bolts*
Arp head studs (torqued once)
Oem p72 timing belt*
Oem p72 water/oil pump*
New tensioner*
Oem honda main/rod bearings*
Oem breather box*
Golden eagle lsvtec conversion*
Obd2 alternator
Alternator bracket
**cams were degreed +3.1ex , -1.1 int
Also have itr fuel rail w/new rc310cc injectors*
68mm throttle body (new tps sensor and gasket)
Iacv w/new gasket
Freshly resurfaced oem itr flywheel
Hydro b16 tranny
Old Dec 9, 2015 | 07:15 AM
Bump*
Old Jan 4, 2016 | 02:00 PM
Bump. B16 tranny sold.
Now has an itr manifold
Old Jan 4, 2016 | 02:01 PM
$2350 shipped.
yarara0825
Jan 30, 2008 03:23 PM
racinhatch
Jun 22, 2007 03:53 PM
BrainzIRL
Mar 22, 2006 05:52 PM
BigBodySmith
32
Jun 17, 2004 03:52 PM
DVS2000
Jul 2, 2001 11:15 PM
