Earthing system connections ?
Old Nov 6, 2002 | 06:50 AM
Ryuji's Avatar
New User
Default Hearthing system connections ?
Hi,
I read some post on earthing system...
But if I want to make my own, where do I have to connect the wires
(from what part to what part) ?
Old Nov 6, 2002 | 08:31 AM
Doctor CorteZ's Avatar
Default Re: Hearthing system connections ? (Ryuji)
should be
vtec solenoid
intake manifold
TB
alternator
upgrade oem block ground and tranny ground
upgrade battery ground
I may have forgotten one....
Old Nov 6, 2002 | 08:43 AM
Tommy_Gunns's Avatar
Default Re: Hearthing system connections ? (Doctor CorteZ)
vtec solenoid
intake manifold
TB
alternator
Old Nov 6, 2002 | 08:54 AM
92sleepR's Avatar
New User
Where on the alternator exactly? Any one of th emount bolts? the housing? Wherever?
Thanks!
Mike
Old Nov 6, 2002 | 11:47 AM
Default Re: Hearthing system connections ? (92sleepR)
just so its grounded is fine.
Old Nov 6, 2002 | 11:51 AM
Chris N's Avatar
bolts are fine to ground. Talk to Tommy Guns (only person I can think of off the top of my head that has the system) about where exactly if you are worried about it.
Old Mar 21, 2003 | 01:44 PM
servion's Avatar
should be
vtec solenoid
intake manifold
TB
alternator
So... do you just run a new ground wire from each of those to a common ground on the frame?
Old Mar 21, 2003 | 03:36 PM
AK94CIVICGRL's Avatar
Default Re: Hearthing system connections ? (servion)
yeah thats what i was wondering, do you link all these together like a chain or having them all grounded to one source?????
Old Mar 21, 2003 | 04:52 PM
RagingAngel's Avatar
Default Re: Hearthing system connections ? (AK94CIVIC)
Ground only to one location...
Old Mar 21, 2003 | 05:27 PM
bluesaint's Avatar
Default Re: Hearthing system connections ? (RagingAngel)
all went to the same negative ground point with the battery's ground.
http://www.imbecilicracing.com/Bluesaint/tg.jpg
Old Mar 21, 2003 | 08:11 PM
servion's Avatar
Default Re: Hearthing system connections ? (bluesaint)
sounds good....
do you run a separate wire from each of the listed sources to the single point? or do you daisy-chain them
Old Mar 21, 2003 | 10:09 PM
2fknlo's Avatar
you missed the ground from the valve cover to the front radiator support.
I too would like to know how to make your own grounding kit.
Will 8 gauge cabel be ok?
Old Jun 11, 2003 | 08:48 PM
Padawan's Avatar
Darth ModerVader
Old Jun 12, 2003 | 04:07 PM
Thrillhouse's Avatar
Default Re: Hearthing system connections ? (Padawan)
Hey thanks for the info on the grounding kit! I have one question tho. Do you daisy chain the wires together or does each grounding point have to go to the negative terminal with separate wires? Thx man
Old Jun 12, 2003 | 04:30 PM
itr-j's Avatar
Default Re: Hearthing system connections ? (Thrillhouse)
ttt
Old Jun 12, 2003 | 05:53 PM
gohandbz8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse &raquo;</TD></TR><TR><TD CLASS="quote">Hey thanks for the info on the grounding kit! I have one question tho. Do you daisy chain the wires together or does each grounding point have to go to the negative terminal with separate wires? Thx man</TD></TR></TABLE>
Most kits I've seen installed had each wires run to the negative on the battery.
Old Jun 12, 2003 | 10:55 PM
TheGSRGuy's Avatar
Default Re: Hearthing system connections ? (gohandbz8)
Unless you have some monster audio system, the stock grounds are probably fine.
Old Jun 12, 2003 | 11:53 PM
skafia's Avatar
25 Year Member
Default Re: Hearthing system connections ? (TheGSRGuy)
The Spoon grounding system I just purchased only had the following:
Negative Terminal Ground
Alternator Ground
VTEC Solenoid Ground
Front Head Ground
RedlineMotive
Jan 23, 2010 07:51 AM
RedlineMotive
28
Sep 22, 2009 08:45 PM
j-bird20
Nov 16, 2007 08:04 PM
LX4CYL
Jun 5, 2003 10:07 AM
ophdehEEzY
Apr 2, 2003 02:48 PM
