CEL question
i have a 99 Si(US ex) i have a big exhuast leak where the header and the catayltic converter meet could this codes be caused by that or what else is causing these codes?
Codes:
P0171
1. Fuel Metering Too Lean
2. Fuel System Too Lean ( Right bank (bank 1)
3. Rear bank (bank1) Fuel System Too Lean
P0131
1. HO2S (B1) S1 Circuit Low voltage
2. HO2S (B1) S1 Low voltage
3. O2S (HO2S) (S1) Voltage Low
P0303
Misfire No3 Cyclinder
P0304
Misfire No 4 Cylinder
P0300
Random Misfire
Codes:
P0171
P0131
P0303
P0304
P0300
Random Misfire
If you haven't driven the car, then you don't know that it runs fine. All of the O2 codes you have there are related to the primary O2 sensor, not the cat or secondary O2 sensor. Do you have the OEM exhaust manifold, or aftermarket? If you know there's an exhaust leak, why don't you fix it?
And exactly where in your header is the primary O2 sensor installed? Near the head flange in one of the runners? Near one of the mid point collectors? Near the final collector? Near the cat flange?
kaj
Honda Civic (2001 - 2005)
Sep 8, 2008 04:35 PM
shermanyang
Nov 26, 2003 12:34 PM
