In cabin wire harness clean up questio
Hey guys, before i start, yes i have searched all over the place for info but have only come up short.
The car is a 93 civic hatch dx model with a gsr swap.
I decided to remove all my heater/ac components, headunit, and srs equipment from my car as its only a weekend street/track car.
I'd like to know if there is any companies that offer products or services like a tucked cabin harness or if you can send your harness in and have it cleaned up/remove all unnecessary wires. I'd also appreciate any input as to removing wires myself.
I already have a nice ryewire tucked engine harness BTW.
Thanks for any input or helpful advice!
A tucked cabin harness? The cabin harness goes under carpet. It's not visible. There's no reason for a company to "tuck" it. Just pull out the wires you don't need yourself. If you just want to remove, that's easy.
Yea I'm currently in the process of doing that. This was all started out of boredom lmao. I plan to have a dash with as little wiring behind it as possible.
It is tucked...its behind a dash and you can't even see the harness because its farther up near the windshield, is it not?
But I'm sure you're more after getting rid of unnecessary plugs so that means you'll have to unravel the electric tape and trace back wires to the plug and de-pin them.
MattsGreenEG
Nov 29, 2007 11:19 AM
Superhatch
Jul 10, 2002 04:37 AM
I mean, I don't see a reason to it, but you do you.
