Starting and idling issue
Old Nov 26, 2015 | 09:21 AM
jayden5885's Avatar
Icon4 Starting and idling issue
94 honda civic ex 1.6vtec
The only thing that seams to be after market is the intake tube and filter
I have a problem with idle fluctuating while idling. Also after I start the car and drive it for a while then turn it off I have to wait 30-45min for it to start back up. Also when it's cold (below 35F) it wont start. Can you please help me fix this problem?
I've checked fuel and spark.
CEL read code 19 which is auto-sylnoyd. Also can that cause the brake light to be on?
At this point I have checked the fast idle valve to.
Nothing that ive done have seamed to help it
Old Nov 26, 2015 | 10:59 AM
Former User's Avatar
Default Re: Starting and idling issue
Clean the IACV and FITV.
State whether the car has a manual or auto transmission.
Old Nov 26, 2015 | 11:11 AM
delsolintegra's Avatar
The brake light being on is probably because the plastic button that is located high up on the brake pedal arm broke and fell out. This button rests on a switch button and keeps the lights off when the brake pedal is at rest. You have to replace that button or some people hot glue a penny in its place to keep the brake lights off.
If you get under there with a flashlight you'll probably see what I'm talking about. It's high up the brake arm and the switch is mounted to the bottom of the dash.
Old Nov 26, 2015 | 11:12 AM
Or the brake fluid is low due to brake pad wear.
Old Nov 27, 2015 | 10:32 AM
jayden5885's Avatar
It's a manual
As far as the brake light I'm talking about the one on the dash cluster. Brakes were just changed and brake fluid is full
Old Nov 28, 2015 | 09:33 AM
92civicdxhatch's Avatar
Do you have gas in it!!
Jun 20, 2013 11:17 AM
crx89k20
May 20, 2011 01:09 PM
Drokit22
Jan 3, 2009 02:31 PM
EvenStar
Mar 7, 2008 02:52 PM
1234567899876543211230
Sep 1, 2006 02:39 PM
