99 d16y8 to 98 d16y7
I have a 99 civic Canadian Si(US EX) with a d16y8 that blew up, i have a 98 hatch with a d16y7. I was wondering if i could swap the alt,dizzy, and injectors from the d16y8 on to the d16y7 and use the obd2b harness and then buy the obd2b d16y7 ecu
would this work?
would this work?
You'll need to use Y7 injectors - they're a little smaller, and using Y8 injectors will cause issues. You also may have to convert your IACV. A how-to can be found here. For converting from 2 wire to 3 wire, just reverse the instructions.
Ser1N
12
Dec 3, 2007 09:36 AM
91hondacrx
Jan 3, 2003 12:15 PM
