Lost All My Gears
Was coming off the freeway and was down shifting to 1st (4 spd) went ftom 4, 3, 2 and when I attempted to go into 1st (clutch fully in) it grinded like the clutch was not in, and when I tried to take off from the stop, it acted as if it were going into the gears,but acted as if it was in neutral. I tried 2, 3, 4, and R. I also heard a tiny metal clanking noise as it was grinding initially. Curious if maybe something got disconnected from the shifter to the tranny because I don't think I would lose my whole transmission via what happened.
Is it possible that its something simple?
Also, could my whole transmission be fried because of this?
I'm thinking I would have heard more damage be done or felt more commotion if my tranny blew.
I'm not too familiar with the drive trains of these things as its my first one. Any info will help
Thanks.
Its a 1990 EF hatch d15 4spd No p/s no a/c
Thanks.
It grinded when going into first because even though the clutch was in, The speed was too high to go into first. If you want to go into first while you're still rolling, you need to rev match.
Also, try changing your transmission fluid. And, as stated above, could be the clutch not engaging properly, or your clutch is worn entirely.
On my first integra i missed a heel toe down shift and dropped the clutch. The rpms went from 1500 to 6000 all at once. Heard a distinct noise. Cars clutch was super heavy after and gears wouldn't want to go in. grinded every gear. The clutch was blown up.
97dxred
12
Aug 8, 2008 05:28 AM
