1320 Ramhorn header. Who has dyno results?
Old Nov 24, 2015 | 07:18 PM
brandonEM1's Avatar
Default 1320 Ramhorn header. Who has dyno results?
Hello H-T.
I am debating on getting this for my stock ITR but want to find more information on it. I have searched but I didn't find any solid proof that this thing is good or trash.
Has anyone tested this header on the dyno? If so, what were the results?
TIA
Old Nov 24, 2015 | 08:46 PM
93egSLEEPER's Avatar
Default Re: 1320 Ramhorn header. Who has dyno results?
What header do you currently have?
I haven't seen anything on it yet either. It's a copy of a good design, but whether or not it was done correctly is a different story. The PLM Toda rep and RMF Narrow headers have proven to be the best all around headers on 1.8's. I say that from experience and research.
Just curious, is the said ITR motor the one making 180/156 in your signature? That's an *** ton of TQ out of a 87mm crank 1.8...
Old Nov 24, 2015 | 09:15 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
1320 is either PLM or an unbranded PLM version.
Old Nov 25, 2015 | 04:32 PM
blackeg's Avatar
I have the 1320 toda rep header. the head flange seems like its warped but when u torque it down there are no leaks so I dont care. besides that it's a solid header especially for the money im quite happy with it
Old Nov 25, 2015 | 05:02 PM
doood's Avatar
been there done that
That header is notorious for leaking at the v-band. Because China.
Old Nov 25, 2015 | 08:21 PM
jdm206's Avatar
I have the toda rep on my build, quality is good and the header seam solid
Old Nov 25, 2015 | 09:06 PM
Ask yourself this. Are you going for looks or quality/power/functionality. I put my money on a toda or rmf narrow any day. Dyno tested results.
Old Nov 25, 2015 | 10:00 PM
ek4serge's Avatar
a copy of dtr header .... who knows if its good or not ,
Old Nov 26, 2015 | 05:29 PM
brandonEM1's Avatar
@93egSLEEPER
I currently have a skunk2 alpha header.
Last time my ITR was on the dyno it made 179/122 with RMF replica on stock p73 ecu.
No my sig was a different setup from several years ago.
I have thought about the Toda rep as well. I was just curious about the ramhorn header because it looks wild.
Old Mar 25, 2017 | 05:29 PM
Eg1990's Avatar
Originally Posted by brandonEM1
Hello H-T.
TIA
I also was wondering if compatible for A/C on a EG Hatchback?? An if so any Pictures Guys.
Old Mar 30, 2017 | 08:15 AM
93eh2b18c1's Avatar
Here's an old setup of mine with plm ramhorn. I only did one dyno with it. Gs-r with s2 tuner 1 cams ctr pistons made 205/143tq. That setup was extremely jacked up internally so those numbers are really just numbers.
As far as a/c clearance its looks ok. Ive never had it in my eg. Pic you can judge for yourself. Biggest Complaint i had was that its all crammed over in the air intake side. So i was sucking in hot air. May have to ajust your radiator releif hose as well and have a thin fan.
Old Apr 1, 2017 | 12:10 AM
vtecmaster85's Avatar
good numbers man
TitanMotorsports.com
335
Sep 3, 2008 04:56 PM
Del Soouulll
15
Apr 11, 2007 10:23 PM
louie3252
Mar 24, 2006 10:51 PM
jeremy.
39
Dec 12, 2003 08:06 AM
