92 Civic VX/B18B1 swap - code 41
Old Nov 23, 2015 | 09:23 AM
AdognamedBoost's Avatar
Default 92 Civic VX/B18B1 swap - code 41
I have a 92 Honda Civic VX with a B18B1, Im currently using a OBD1 P75 and my problem is the cel lights im throwing particularly code 41. Now here is what gets tricky. I have a O2 sensor down by the header collector and its a 4 wire sensor, but I cant find the plugs to the harness for the life of me, I tried looking up images and had zero luck.
So my question would be, can someone show me what plugs im supposed to be looking for? If I dont have the plugs what are my alternatives? I thought about wiring up the O2 to the ecu directly but I was also curious on what type of wire I should use to splice into the other wires on the?
Old Nov 23, 2015 | 12:04 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default re: 92 Civic VX/B18B1 swap - code 41
.:FFS TechNet : OBD1 ECU Pin out Schematics :.
If memory serves correctly, the VX uses a 5 wire O2 sensor. You won't find a direct plug in O2 sensor that'll work with your ECU. You'll need to either replace your harness, or just wire a standard 4 wire O2 sensor into your ECU using the wiring diagram I posted above.
Old Nov 23, 2015 | 12:45 PM
Thanks guy!
If i replace the wire harness which one do i use? Any specific wires i should use to run the O2 sensor?
Old Nov 23, 2015 | 01:15 PM
NotARaCist's Avatar
If you want to swap the harness, a 92-95 EX or SI harness should work. You might be able to use an Integra engine harness, since they're both 2 piece harnesses, but I'm not 100% sure on that.
If you just want to wire up the O2 sensor yourself (which is personally what I'd do, unless there are other issues you haven't mentioned), then just 16g wire, some solder, crimps, heat shrink, and corrugated tubing, and you'll be totally fine.
Old Nov 23, 2015 | 01:53 PM
eghatch9295's Avatar
Stancetard Hate Monger
use the dx/lx harness. cheaper, you aren't running vtec anyways. easiest solution is to run the wires to the ecu.
Old Nov 23, 2015 | 03:09 PM
Thanks for the help i just finished wiring it and the code is gone, only thing i have left is a tps sensor and barometric pressure sensor. Any ideas about the last one?
Old Nov 23, 2015 | 03:31 PM
NotARaCist's Avatar
A baro code is a sure fire sign of one of two things. Either the ECU is fried, or you're reading the code incorrectly.
Old Nov 23, 2015 | 03:34 PM
Im sure its not fried, it works just fine. Maybe i did read it wrong then my other guess would be a code 12
Old Nov 23, 2015 | 03:42 PM
NotARaCist's Avatar
Use your smartphone, make a video of the blink codes, upload that video to Youtube, and post it here. We can help you read it.
Old Nov 23, 2015 | 03:46 PM
Will do tomorrow, its already dark over here.
Old Jan 18, 2016 | 09:42 AM
Default Re: 92 Civic VX/B18B1 swap - code 41
Old Jan 18, 2016 | 09:55 AM
Former User's Avatar
Codes 7 and 13.
13 suggests ECU is bad.
Old Jan 18, 2016 | 09:56 AM
tony_2018's Avatar
Fish Twig
ecu bad
Old Jan 18, 2016 | 09:58 AM
Thanks for the input
Old Jan 18, 2016 | 10:00 AM
Verify that both codes return after resetting ECU.
Old Jan 18, 2016 | 11:08 AM
I did the reset now it's only 13
Old Jan 18, 2016 | 11:31 AM
Bad ECU.
Old Jan 18, 2016 | 07:02 PM
I was looking around and read that the sensor can be be bypassed with a chip, Now Id hate to get another ECU and then get it socket-ed again for a chip.
so my question is can I still use my ECU since its socket-ed already and just get the chip programmed?
Old Jan 30, 2016 | 08:28 AM
I finally sourced a virgin p75 and I hooked my tps sensor back since its been sputtering around 2500prms and at 2900 rpms and I thought maybe it's an unrelated problem from the ECU with the new one I didn't have any CELs but the problem was still there until I disconnected the TPS.
Now I bought a new one but now I think I just may need an adjustments on the positioning of the sensor with a multimeter on the old one since there wasn't a CEL anyone can verify?
lowntegra
May 25, 2007 06:57 AM
sonicivic
Feb 17, 2006 09:47 AM
dturbo
Jun 8, 2005 06:16 PM
shivic
Aug 25, 2004 01:57 PM
T-sohctec
Aug 17, 2002 05:31 AM
