Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Odd Transmission Behavior 01 Civic AT 207k Miles
Old Nov 22, 2015 | 10:09 PM
cometflyer's Avatar
Default Odd Transmission Behavior 01 Civic AT 207k Miles
I did a long overdue transmission fluid change about a month ago. On first drive after the change the car started shifting weird and has been ever since, although it is worth noting this does not happen every shift, maybe about 5% of the time.
What it feels like its doing is shifting, then immediately downshifting, then shifting again with a higher than normal rev after shifting. This is all while keeping the foot on the pedal at a constant speed. There is no thud or jerk to the car like I would expect if the transmission was slipping.
  • Yes I used the right type of fluid.
  • After parking on a level ground with car at operating temperature the dipstick measures at just over the high mark.
Old Nov 23, 2015 | 06:28 AM
NDNV's Avatar
Default Re: Odd Transmission Behavior 01 Civic AT 207k Miles
By right type of fluid you mean Honda DW-1 ATF? One drain and fill?
Old Nov 23, 2015 | 08:05 AM
cometflyer's Avatar
DW1 ATF And that started after one drain and fill. Since I've done another and plan on doing one more.
Old Nov 25, 2015 | 08:27 PM
that_boy_sammy's Avatar
That 207k mile tranny fluid was married to that transmission. And you separated them apart.
Old Nov 25, 2015 | 08:32 PM
Take a pint or quart out and try putting in a Lucas additive. And remember HONDA AUTO TRANSMISSIONS ARE CHECKED WITH THE ENGINE OFF.
dgdarien
Mar 30, 2018 05:13 AM
dankoty
Honda CR-V & Element
11
Jan 8, 2017 03:38 PM
northtexas
Honda Civic (2006 - 2015)
10
Sep 25, 2013 09:29 PM
eddieE
Feb 4, 2013 05:12 PM
Blacknight117
30
Jul 3, 2011 07:25 AM
