Gas=beer help
Old Nov 22, 2015 | 06:16 PM
shawn_crx's Avatar
Default Gas=beer help
Engine = b20 with ycp high comp piston vtec b16 head with GSr cam.
Engine running fine, idle set to 850, timing 16 degree, but just idling the car for 10 min it burn thru 1/4 tank of gas.
Why so much gas used.
Exhaust are brand new, 3" cat back, and stock injectors. My 440cc runs rough, fuel pressure set to 37 lbs, 255lph fuel pump.
Need help to trouble shoot high fuel usage
Old Nov 22, 2015 | 06:17 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Gas=beer help
Because your tune is nonexistent. Get that thing tuned.
Old Nov 22, 2015 | 07:45 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
No car present, only an engine. Moved to Tech/Misc as this isn't about a car, only a motor in some mystery vehicle.
Old Nov 23, 2015 | 05:24 AM
v4lu3s's Avatar
RTFM
You are burning a ton of gasoline because you are giving the car at least double what it should have it sounds like. original injectors 240cc, now 440cc, original pump probably 130lph, now 255lph....needs to be tuned...
Old Nov 23, 2015 | 07:53 AM
shawn_crx's Avatar
93 civic hatchback
riceball777
May 22, 2015 11:57 AM
thewrai6th
May 17, 2011 01:00 PM
bazoOKA_ TOoth
12
Sep 30, 2010 02:45 PM
phoshyzzle
Engine Management and Tuning
14
Apr 14, 2010 04:48 PM
datnigabluberry
Mar 29, 2007 05:53 AM
