Civic b16a2 power loss
Old Nov 18, 2015 | 08:02 PM
lustworld's Avatar
Default Civic b16a2 power loss
Whats up honda fam
Here i am again with my engine issues.
I have a b16a2 currently on a p2p ecu now i had idle issues... i flushed my radiator fluid and it seems to be idling where it should be... it sometimes stays high at a red light... but thats it.. my issue now is
I do a burnout just fine but when i dump it on second gear, my gears go from 8k down to 4k then goes back up slowly
I tried an s300 tuned on hondata and it dies when i slam it in first gear... and also tried a few p28s ive had idle issues with most... still dies only when i shift to second gear during a burnout.. need to know what may be causing this.. someone said it is because i dont have at least 1 o2 sensor plugged in... others say it could be due to the converter below being clogged
It has a new clutch refurnished flywheel
My car drives like a dream on the streets and and highway daily driven but Again my car still idles weirdly with a stock p2p ecu but its yet the only ecu it can run okay on.. without idling like crazy..i cannot use a b16 ecu because that is obd2b and my harness is obd2a.. which is why i was given a bunch of chipped p28s any suggestions please?
Old Nov 18, 2015 | 08:10 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Civic b16a2 power loss
I've already told you how to fix your problem.
Originally Posted by NotARaCist
You're using the wrong ECU for the engine, and you're wondering why it doesn't run right? ECUs aren't "one size fits all". You can use an OBD2A to OBD2B adapter and use the correct OEM ECU, or you can use an OBD2A to OBD1 adapter, and use a chipped ECU of your choice.
Your CKF sensor wires are very obviously hanging there doing **** all. Wire the sensor properly, and plug it into the harness. It's a 2 pin connector down there, blu/red wht/red if memory serves correctly. You had to unplug it to remove the old engine. Get the proper ECU. Get rid of that aftermarket FPR, and get a stock unit. It also looks like you have an uncapped port on the back of your intake manifold - cap that.
Or take it to a tuner, and get it properly tuned with one of your random ECUs.
Old Nov 18, 2015 | 08:33 PM
lustworld's Avatar
I found that im leaking through one of my injectors slightly, you can see dry marks on it... also, my throttle body could be stuck... i rev it by hand and sometimes i have to force it back... by a bit... i have the correct ecu and basemap with same issue
Old Nov 18, 2015 | 08:49 PM
lustworld's Avatar
Now that the ecu is in place, Im having trouble with power loss..
Old Nov 18, 2015 | 10:15 PM
NotARaCist's Avatar
You literally just said in your original post that you're using a P2P ECU. That is not the correct ECU for the engine.
Old Dec 14, 2015 | 03:52 PM
lustworld's Avatar
I'm using an s300 ecu now. Bought it brand new. I rev it to launch control. And it slowly dies then picks up slowly and starts shifting strong.... is there a reason how this can happen, has anyone ever experienced this? If so what solved it...
Old Dec 14, 2015 | 03:57 PM
NotARaCist's Avatar
And what tune is on the S300?
2greedy
Sep 18, 2015 10:20 AM
chevymeister
Transmission & Drivetrain
Nov 21, 2013 11:17 AM
antman2x2
Honda Civic (2001 - 2005)
10
Jul 13, 2012 02:54 PM
hybridEj6
Aug 9, 2003 09:07 PM
