Condenser fan won't shut off
Old Nov 18, 2015 | 12:51 PM
napa2u's Avatar
Default Condenser fan won't shut off
Ok here goes. 94' Honda Accord- the condenser fan runs continuously. I pulled the fuse to get it to shut off. The cooling fan fuse was bad ( not sure the reference!). I tried switching out the relay but still have the problem. Any ideas as to what's going on? The engine was completely cold for 3 days and put the fuse back in and the condenser fan ran continuously.
Thanks,
Barry
Old Nov 18, 2015 | 02:52 PM
poorman212's Avatar
Default Re: Condenser fan won't shut off
Just me but I'd rather refer to them as the drivers side and pass side fan's.
SO is this the drivers side cooling fan that is running at all times? Also the relay for that fan is "clipped"/bolted just behind the rad on the drivers side - two relay together (ac compressor and drivers cooling fan)
Old Nov 18, 2015 | 05:02 PM
napa2u's Avatar
Yes, it is the drivers side fan.
Old Nov 20, 2015 | 03:08 PM
poorman212's Avatar
Ok, which relay did you switch....the one in the fuse box or the one by the drivers side headlight?
Have you had the car for a period of time or is it new to you......if you have had it for a while, was there any recent work done to the car?
Old Nov 20, 2015 | 03:34 PM
napa2u's Avatar
i switched the one by the driver side headlight. had the car for awhile. the radiator hose split and the owner replaced it (I'm a friend) and they replaced the battery as well. no other work was performed.
napa2u's Avatar
and i switched out the one in the fuse box as well.
Old Nov 20, 2015 | 04:11 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Do you have a voltmeter/multi-meter for testing?
Old Nov 21, 2015 | 06:25 AM
napa2u's Avatar
yes i do
Old Nov 21, 2015 | 06:56 AM
poorman212's Avatar
Not trying to be confusing - two people giving answers/suggestions, I'm pretty sure I know where "tech" is going - until more info from him try this simple test with the volt meter.
The drivers fan relay (Cond Fan) - has four wires. Pull the relay and the key off.
The WHT wire should have 12v
The GRN wire SHOULD NOT have continuity to ground - open
Also - what happens to the fan motor if you unplug the green connector on the housing where the upper hose connects to the engine.
Old Nov 21, 2015 | 07:31 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Yes, we're heading in the same way.
Continuing with poorman212 instructions regarding testing the wiring that went to the condenser fan relay:
1. With the voltmeter's red lead touching the Yel/Wht wire cavity terminal, and the voltmeter's black lead touching body ground or the negative battery terminal; do you get a voltage reading?
There should be no voltage/power at the Yel/Wht wire with the ignition key in off position. If there is power on the Yel/Wht wire under this condition, the issue may be a short in the wiring (e.g., wire touching another power wire) or an issue with the radiator fan control module.
2. If there was power at the Yel/Wht wire in test #1. With voltmeter's red lead touching the Yel/Wht wire cavity terminal, this time with the voltmeter's black lead touching the Grn wire cavity terminal; do you get a voltage reading?
If you also get a voltage reading on the Yel/Wht under this condition, there is probably a short also on the Grn wire for the ground (-).
These tests are to narrow/isolate the area of the issue(s).
Old Nov 23, 2015 | 10:20 AM
napa2u's Avatar
Going thru testing now. Unplugging the green connector has no effect on fan motor
Old Nov 23, 2015 | 03:28 PM
poorman212's Avatar
Check that the relay you are looking at has the correct wire colors listed.
YEL/WHT
WHT
GRN
BLU/YEL
Old Nov 24, 2015 | 06:03 PM
napa2u's Avatar
where exactly is it located? and thanks for sticking with me. Also, Happy Thanksgiving to you and your family
Old Nov 24, 2015 | 06:24 PM
poorman212's Avatar
Wait, I thought we covered that?
There are two relays bolted just below the drivers headlight. One for the AC compressor and the other is for the driver/left side cooling fan................
clowery89
Jun 23, 2010 06:17 AM
FLCivic
Dec 18, 2007 04:37 PM
Taikonaut
Nov 4, 2005 11:26 AM
90Accord-R
Oct 17, 2003 07:30 AM
Nos4R2
Jan 26, 2003 09:40 PM
