2000 Honda Civic DX chokes when accelerating
Old Nov 17, 2015 | 03:31 PM
Himynameismatty's Avatar
Default 2000 Honda Civic DX chokes when accelerating
Hello everyone, I'm new here and naturally as someone who is nervous about a possible issue with their car, I came here for answers. I own a 2000 Honda Civic DX with 160 k miles. Recently, the car chokes if I accelerate too much. I take it on the highway all the time and it doesn't really do it once I'm going but I'm definitely concerned. Does anyone know what this can be or am I going to have to take it somewhere to be diagnosed? I'd obviously like to fix it myself if it's simple. Thank you in advance for any help you can provide.
Old Nov 17, 2015 | 04:28 PM
Ohmega's Avatar
Default Re: 2000 Honda Civic DX chokes when accelerating
https://honda-tech.com/honda-civic-d...sting-3002401/
ALMOST got everything covered for a good first post, but you missed a few things.
What transmission type?
Does the CEL function, and if so, are there codes?
Provide engine as well (we can all google what engine goes in a 2000 Honda Civic DX but that's not that point)
Old Nov 17, 2015 | 04:48 PM
Sorry about that. It's a 1.6 liter engine. Not vtec. Automatic. No check engine light present and haven't had it checked for other codes yet. I did have a recent issue where the front part of my cat snapped so the car is running a little loud now. I don't think this is related because it started doing this before that. I'm in the process of having that fixed.
Old Nov 17, 2015 | 05:04 PM
NotARaCist's Avatar
I never narc'd on nobody!
When was your last full tune-up, including plugs, wires, cap, rotor, and fuel filter? Do you own a multimeter?
Old Nov 18, 2015 | 01:54 AM
delsolintegra's Avatar
You may have had a restricted cat before it "snapped". Now it's a O2 sensor related problem because of an exhaust leak. Get all that fixed and squared away than you will have to reset the ECU and than start reading any Cel codes that come up.
Old Nov 18, 2015 | 06:51 AM
The last tuneup was right before I bought the car from the previous owner last year. I don't own a multimeter but I believe my friend does.
Old Nov 18, 2015 | 06:57 AM
Which brings me to my next question. I know someone who jacked my car and knew the issue with my cat before he even saw it. He said he would put a sleeve on it and weld it for $100 under the table. Is that what would fix this issue with the cat? He definitely sounded like he knew what he was talking about. He has his own welding gun too. When he lifted the car, he showed me the separation of the cat in the front of the car and then put it back together and the loud sound was gone.
Old Nov 18, 2015 | 07:17 AM
eghatch9295's Avatar
Stancetard Hate Monger
thats a ripoff. you can get a new universal cat and have it welded on for a coupe bucks more. as to your hesitation- a more detailed description of the symptoms would be very helpful.
edit: just noticed you've got a dx. a simple weld job should run around 50 bucks. a brand new cat, manifold, and downpipe is $158 on rockauto.com and can be bolted on
Old Nov 18, 2015 | 09:22 AM
I feel like the car has lost some power as well. I can get it to 65 or 70 on the highway but it seems a little tough to get it there. I'm not trying to push her too hard until I get this issue fixed.
So as far as a weld job, would they just get a metal sleeve the bring the whole cat back together?
As far as bolting on, is it that simple with a cat? There is no welding needed if I was to buy a new one? What would be the cheapest and best option for me at this point as far as parts and labor?
Thank you everyone for your help!
Old Nov 18, 2015 | 09:58 AM
So I don't think it's the cat that snapped but the piece after it leading to the front of the car. Or it's the piece after the fat part leading to the front of the car. Should i try to take a pic?
Old Nov 18, 2015 | 10:32 AM
Ohmega's Avatar
Yes, pictures are worth more than words.
Old Nov 18, 2015 | 04:11 PM
Okay. My brother in law is going to jack it up in a few days so I can take some pics
Old Nov 18, 2015 | 04:15 PM
NotARaCist's Avatar
Then it's time for one, anyway. Definitely follow through with the exhaust pictures, but while you're waiting for your brother, go to your local parts store and buy a cap, rotor, plugs, and wires. NGK for all of the above - Hondas get touchy when you give them non-OEM ignition components. If the fuel filter was replaced last year, you can get away without replacing that again until next year. The tune up might even help with the problems you're having, which is why I asked.
Old Nov 18, 2015 | 04:20 PM
Thank you for the advice. I'll definitely get the tuneup done asap. Once again, you have all been a great help. Can't wait for her to be running normal again!
Old Nov 18, 2015 | 08:21 PM
go on rockauto.com, and have a look at their converters. they come with manifold, converter, gaskets, and hardware for $158. Odds are, yours is original, and if it is, look at the area surrounding the oxygen sensor. I'd bet anything there is a crack there, very common with that particular manifold. Your symptoms and description of them are vague at best, so it could be a bunch of different things. NARC led you in the right direction with a basic tuneup, as it is cheap and would rule out a couple different things. Typically, with these symptoms and your generation Civic, the problem lies in the distributor. Do you own a multimeter?
Old Nov 21, 2015 | 04:22 PM
As you can see in the photos, part of the exhaust snapped. My friend said that this is the piece I should get to replace part of the exhaust system: https://www.upsw.com/2000-honda-civic-dx-16l-hatchback-exhaust-resonator-pipe/?gclid=CNyrrJvPoskCFU2RHwodDy8Imw. He said he would install it for $80 for me. Is that the best price I can find for this piece?
Old Nov 21, 2015 | 04:34 PM
no. hes raping you on the install, hard. 120 should get you a whole new exhaust at a muffler shop
Old Nov 21, 2015 | 04:39 PM
$120 as far as the part I need with install included? That seems a bit low, no?
Old Nov 21, 2015 | 04:43 PM
no i mean from manifold back. its your money, but for an exhaust shop made system ive never paid over 150.
MugenRNR
Northern California (Sales)
Dec 17, 2018 02:40 PM
MrStudioCans
Aug 30, 2016 03:08 PM
sanchg3
35
Mar 21, 2015 01:25 AM
