MASSIVE garage sale! OEM and aftermarket parts.
More parts to come.
All sales are final.
No returns or refunds.
Reasonable offers will be considered.
Prices do not include shipping or Paypal fees.
Located in 45840.
Added 11/22/2015:
90-91 Civic mudflaps
88-91 Civic tail light garnish
OEM Honda equalizer
AEM air filter
Added 12/27/2015:
94-01 Integra center console
Added 2/24/2016:
94-01 Integra dash vents
94-01 Integra moonroof switch
94-01 Integra glove box light
94-01 Integra hazard switch
94-01 Integra cruise control switch
Engine:
B series OBD1 OEM alternator. $60.00
B series OBD1 starter. $60.00
B series GSR AC bracket/ lower engine mount. $40.00
B18C1 secondaries. Throttle plates won't turn by hand. $20.00
D series flywheel. Two available. $40.00
K series crank pulley bolt. $10.00
K24A8 intake manifold cover. $25.00
K24A8 RAA intake manifold and injector base. $75.00
K24A8 cylinder head. $200.00
K24A8 oil pump. $40.00
k24A8 flex plate. $25.00
K24A8 exhaust manifold with heat shield. $35.00
K20A2 OEM clutch and pressure plate. $50.00
K20A2 OEM flywheel. $50.00
K20A2 throttle body. Missing TPS. $125.00
K20A2 power steering pump. $75.00
K20A2 AC compressor. $75.00
K20A2 alternator. $75.00
K20A2 exhaust manifold. $35.00
K20A2 exhaust manifold heat shield. $15.00
92-95 Civic DX/EX/LX/SI OEM exhaust manifold. $35.00
92-95 Civic DX/EX/LX/SI OEM exhaust manifold heat shield. $15.00
92-95 Civic D series rear manual transmission bracket. $20.00
92-95 Civic D series AC bracket/lower engine mount with ilder pulley. $35.00
92-95 Civic D series AC bracket/lower engine mount. $25.00
92-95 Civic aftermarket aluminum radiator with OEM fan. Works with manual and auto transmissions. $60.00
92-95 Civic OEM air conditioning setup. Came off a 93 CX. Everything down the the bolts. Only think needed is the wiring harness. Has not been converted to R134a. You can convert it from buying the kit from honda or buy R12 on Ebay or Amazon. $200.00
92-95 Civic CX/VX OEM exhaust manifold with catalytic converter and downpipe. $45.00
B/D series EG/DC engine mounts. $15 each.
OEM oil cap. Three available. $5.00 each
AEM air filter. One has RTV on a tear on the endcap. $10.00 each.
Universal air filter. Hose clamp included. One cone style and six foam style available. New. $15.00 each.
Megan Racing test pipe. Inlet 2.25" ID, outlet 2 3/8" ID and 16 3/8" in length. Should fit 94-01 Integra LS. New. $40.00
Suspension:
Eibach/Ground Control race springs. 7 x 2.5 x 250. $70.00
Eibach/Ground Control race springs. 8 x 2.5 x 380. $70.00
Eibach ERS race springs. 8 x 2.5 x 450. $70.00
92-95 Civic/94-01 Integra Hardrace front compliance bushings. New. $75.00
92-95 Civic/94-01 Integra Hardrace front upper control arm bushings. New. $45.00
92-95 Civic/94-01 Integra Hardrace rear toe arm bushings. New. $45.00
92-95 Civic rear lower control arms. $30.00
92-95 Civic front shocks. $35.00
92-95 Civic rear shocks with lower control arms. $35.00
94-01 Integra 24mm front sway bar. Two available. $40.00 each
94-01 Integra 14mm rear sway bar. Two available. $40.00 each.
94-97 Accord front right upper control arm. New. $20.00
94-97 Accord front strut bar. New. Two available . $20.00 each
Brakes:
92-95 Civic CX/DX/LX/VX front calipers. $35.00
92-95 Civic drum brake trailing arms. $100.00
92-95 Civic CX/DX/LX/VX knuckles. $75.00
94-01 Integra knuckles. $125.00
94-01 Integra front hubs. $45.00
Located in 45840.
Added 11/22/2015:
OEM Honda equalizer
AEM air filter
Added 12/27/2015:
Added 2/24/2016:
Engine:
Suspension:
Brakes:
Interior:
94-01 Integra dash vents. $10.00
94-01 Integra moonroof switch. $15.00
94-01 Integra glove box light. $10.00
94-01 Integra hazard switch. $15.00
94-01 Integra cruise control switch. $15.00
94-01 Integra steering wheel. $30.00
94-01 Integra center console pocket. Two available. $10.00
94-01 Integra clock. $15.00
94-01 Integra dash bolt cover. Located on each side where the door meets the dash. $10.00
94-01 Integra upper seat belt trim. $5.00 each.
94-01 Integra seat bolt covers. $10.00
94-01 Integra rear seat latch. $10.00
94-01 Integra top steering column cover. $10.00
94-01 Integra door panel. Drivers side switch is sold. $40.00 each
94-01 Integra cargo cover. $75.00
94-01 Integra hatch pillar trim. $25.00
94-01 Integra right side A pillar cover. $20.00
94-01 Integra fuse/kick panel. $20.00
94-01 Integra center console. $40.00
94-01 Integra shifter console. Shifter surround broken, cupholder works. $10.00
94-01 Integra dashboard. $150.00
92-95 Civic hatchback rear window trim. Painted black. $20.00 each
92-95 Civic A pillar trim. Painted black. Passenger side has LED light. $15.00 each.
92-95 Civic sill trim. Bent and missing tabs. $5.00 each
92-95 Civic door panel. $40.00 each
92-95 Civic signal/wiper stalks. $25.00
90-93 Integra carbon fiber gauge trim. New. Two Available. $25.00 each.
OEM Honda equalizer from unknown model. There is some electrical tape on the bezel, missing a button. $25.00
Exterior:
98-01 Integra FBP power mirrors. $75.00
98-01 Integra FBP rear bumper cover. $150.00
94-01 Integra GSR FBP rear wing. 3 of 5 mounting screws broken. $20.00
94-01 Integra OEM red/clear tail lights with gaskets. $150.00
94-01 Integra carbon fiber style tail lights with gaskets. New. $50.00
92-95 Civic headlights. $75.00
92-95 Civic hatchback altezza tail lights. Inner lights are cracked. New. $20.00
92-95 CIvic hatchback rear wing. $35.00
92-95 Civic hatchback PCI GT wing brackets. New. $300.00
Aluminium rear wing. New. $50.00
90-91 Civic hatchback mudflap set. $80
88-91 Civic tail light garnish. The Si part needs new clips. $50.00 for the base and $75 for the Si.
88-91 Civic hood bra. No tears, good shape. The lettering was tahitian green at one point. $100
Miscellaneous:
92-95 Civic CX/VX fuel tank straps. $20.00
98-01 Integra cruise control actuator. $25.00
Remote battery terminals. New. $20.00
Valeo Ultimate 15" wiper blade. New. $10.00
Valeo Ultimate 16" wiper blade. New. $10.00
Valeo Ultimate 26" wiper blade. New. $10.00
Exterior:
Miscellaneous:
Dizzy is sold.
Added:
88-91 Civic hubcaps
96-98 Civic hood bra
OEM Honda equalizer
AEM air filter
Added:
88-91 Civic hubcaps
OEM Honda equalizer
AEM air filter
All sold:
Integra rear speaker bracket
Integra rear shock covers
Integra tail light covers
Integra fuel door release trim
Integra trunk light
Integra grab handle
Integra center console bolt cover
Integra lighter and ash tray housing
Integra side panel
Integra trunk panel
Integra carpet
Integra rear seat
Integra trunk light
Integra grab handle
Integra side panel
Integra trunk panel
Integra carpet
Integra rear seat
Added:
94-01 Integra climate control
94-01 Integra defrost switch
94-01 Integra dimmer switch
