b16a 96 civic flashing cel code wen trying to read codes
Old Nov 14, 2015 | 07:37 AM
Fallriverb16's Avatar
Default b16a 96 civic flashing cel code wen trying to read codes
i swapped my harness for a 96 ex harness an converted my injectors an distributor to obd1 with the conversion adapters but now i have a cel witch i didnt have b4 i did all the clips correct i belive cuz i just matched wat i had pluged in b4 now wen trying to pull codes it just shows a long flashing code it just keeps flashing/ blinking idky thank yu for ur help
Old Nov 14, 2015 | 01:37 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: b16a 96 civic flashing cel code wen trying to read codes
Can you post a video?
Old Nov 14, 2015 | 05:51 PM
yes i can an beat example is i jump the service connector an cel just keep blinking long blinks no codes it just keeps flashing every 5 secs an doesnt stop i will show yu tho give yu a better idea
Old Dec 23, 2015 | 10:22 AM
dntnedvtec's Avatar
Okay, well, it is showing you the code/s. Long blink is 10, short blinks are 1.
2 long blinks, 20.
2 long blinks and 7 short blinks, 27.
The flashing is close together and when there is a pause, that is the end of the code.
Record the amount of flashes. it is a continuous cycle. it will keep flashing codes until you either pull the jumper or clear them. Good luck. And, where is that video??
Old Dec 23, 2015 | 01:22 PM
thank yu for the reply i have the video but caint post on hea do to me not having the youtubbe account i have the video an can send yu it threw email if yu have 1 ill send it thank you again also this all happened after replacing my harness to an ex harness 0bd2 an only sensor that was diff was the iat semsor but i kno for sure its rite only thing i think is rong is injecrors or my o2 sensor car mva had a cel light i would put in access an the cel would b on an turn rite off like it should swapped harness an got a cel
Robotn1x
Sep 7, 2012 03:51 AM
soodominican
Aug 12, 2009 12:48 PM
Zerotls
Nov 17, 2008 09:40 PM
t_dot_SiR
May 2, 2007 04:01 PM
ef-sihatch
Jun 19, 2004 06:39 AM
