mpfi help
Old Nov 11, 2015 | 06:07 AM
Joe Yaerrd's Avatar
Default mpfi help
Can you use a dpfi tps on a mpfi manifold and would I be able to use a 0bd1 iacv with my 0bd0 intake manny
Old Nov 11, 2015 | 07:00 AM
jonGSR's Avatar
Default Re: mpfi help
The TPS will not work, it even sits at a different angle. Does the iacv have the same bolt holes? If it lines up it will work.
Old Nov 11, 2015 | 06:17 PM
Joe Yaerrd's Avatar
Seems exactly the same
Old Nov 11, 2015 | 06:18 PM
Joe Yaerrd's Avatar
The tps that is
Old Nov 14, 2015 | 11:58 AM
raymondpowens's Avatar
the MPFI TPS is different from the DPFI. DPFI and MPFI sensors have opposite rotation direction, and the plugs face different sides.
left is DPFI, right is MPFI
Old Nov 14, 2015 | 08:11 PM
Joe Yaerrd's Avatar
Hmmmm that's weird my mpfi one is broke but has 3 prongs
Old Dec 18, 2015 | 12:58 AM
they all have 3 pins on the plug. power wire in, ground wire, and signal out to ECU. what you see in the picture arent the pins for the plug, theyre the plastic alignment pieces for the plug. those two pins, with the little catch for the retainer clip, are what keep the plug properly aligned when plugging it in.
journeyquest
Aug 2, 2014 02:14 AM
gunnerman
12
Oct 24, 2007 09:40 AM
Chugger
Jan 21, 2007 06:21 AM
RCautoworks
Jan 25, 2006 05:16 PM
See Are X
Feb 23, 2003 08:20 AM
