1996 check engine camshaft/starts in neutral
Old Nov 10, 2015 | 11:38 AM
Brandtb's Avatar
Default 1996 check engine crankshaft/starts in neutral
Hi guys I have a 1996 accord and it's throwing a CEL for crankshaft sensor. I also notice that it only starts in neutral. In park it will turn over but die immediately. Any ideas? I think it's too coincidental to be two separate issues. Thanks for any help or advice it's appreciated.
Old Nov 10, 2015 | 12:39 PM
holmesnmanny's Avatar
Default Re: 1996 check engine camshaft/starts in neutral
The crankshaft sensor is essential in starting the vehicle. Whether it starts in park or neutral is irrelavant. Even if you find the reason it will have no bearing on the failure to start the vehicle.
You would first need to get to the sensor at the crank and clean off both sensors and the pulleys that each sensor reads off of. Then make sure the wiring is clean, both on the sensor assembly and the wiring loom as far back as you can check. Make sure there are no burns or tears in the wiring.
Then I would put it back together and after clearing the code I would start-er up.
Old Nov 10, 2015 | 12:52 PM
Brandtb's Avatar
I really appreciate your feedback and will clean the sensors. The car only starts in neutral,it turns over put quickly dies when starting from the park position. Is this related? Thanks again!
Old Nov 10, 2015 | 01:12 PM
After starting in neutral, can you then drive the car normally with no issues ?
Old Nov 10, 2015 | 01:15 PM
Brandtb's Avatar
It bogs a bit when going slow then accelerating. It sputters and feels like it wants ti stall but it doesnt and then it drives normal once its passed thst sluttering. I have a new car so I haven't driven it far because I didn't want to get stuck so that's about all the info I have at this time. Thanks alot
Old Nov 10, 2015 | 01:50 PM
Well, if the code is there you know you need to get that fixed. It's likely that fixing the crank sensor will clear up your car.
I can't say why it's fine in neutral but not in park but I would say it's likely a non issue after fixing the crank sensor issue.
Old Nov 10, 2015 | 03:18 PM
MAD_MIKE's Avatar
MM Gruppe B
Most likely starting issue is due to dirty gear switch.
Rough running is from the crank sensor. Diagnose whether it is dirt fouled sensor or crank sprocket, loose connection, or failing sensor.
kmarolla
Honda Civic (2001 - 2005)
11
Apr 13, 2016 05:53 PM
underb00steg6
Apr 1, 2009 11:13 AM
Fatty_1775
Jan 26, 2009 10:00 AM
e_r_i_c_
Jul 20, 2006 06:04 PM
Smith Wise
Sep 24, 2003 07:41 AM
