Clutch Issue
Old Nov 10, 2015 | 10:23 AM
alexofaao2000's Avatar
Default Clutch Issue
OK so i installed a new stock clutch in my 96 civic. I know its installed right because i have all the gears, and i can drive it. The issue I'm having is i can't seem to get the pedal to gain pressure I've done the crack bleeder push pedal down close bleeder lift up pedal but i still have air in the line with no pressure. I tried to use a vacuum bleeder hand pump to bleed it i have consistent air bubbles and filling the reservoir and now after trying to bleed it if i turn the car on in neutral it take a few good cranks to start and if i hit the gas it stalls out with the pedal in or out. Could the stall be cause by the clutch line having to much air ?
Mike banX
Transmission & Drivetrain
Feb 16, 2011 06:58 PM
crxricer66
Nov 3, 2007 01:44 PM
jdmh22luda
Jul 26, 2007 01:02 AM
SilverDC4
Apr 8, 2005 08:07 AM
Whig-it
Jun 21, 2004 06:21 PM
