Car electrically dying on the road but will start up again.
Old Nov 10, 2015 | 04:59 AM
BLKOUT23's Avatar
Icon4 Car electrically dying on the road but will start up again.
I have a 98 civic LX that I was driving last night in the rain. I noticed my wipers started to move slower, the radio lights started to cut in and out. My dash lights went dim and eventually the gauge needles all fell to the bottom. The car finally died, I sat there on the phone with my wife setting up a tow. I tried to start the car and it fired up and I could drive it again. I went 5 miles and the car started to die again. Did the process over again and I was able to make it home as it i died in the driveway. I never had the charge light come up while driving. Of course the lights on the cluster showed up as if you had the ignition in the on position.
** I bought the car from a guy 2 weeks ago and installed a new battery and alternator.** Any ideas what could be going wrong or where to start troubleshooting?
Old Nov 10, 2015 | 05:38 AM
Former User's Avatar
Default Re: Car electrically dying on the road but will start up again.
Start by cleaning and tightening the battery connectors, and also the G1 battery ground attached to the chassis.
Old Nov 10, 2015 | 05:46 AM
BLKOUT23's Avatar
I was sure hoping you would reply. Seems like you know a ton about these cars. I'm going to get my meter out after class and check the reading on the battery. I can't see the car starting if the alternator is not working and it drained the battery. Correct me if i'm wrong but shouldn't the charge light come on in the car if the alternator is not working?
Old Nov 10, 2015 | 05:52 AM
A battery load test by an auto parts store would be next. This is generally a free service.
Generally yes, if the charge light in the cluster works.
Old Nov 10, 2015 | 05:55 AM
BLKOUT23's Avatar
I assume its safe to say the light is working because I see the light when I start the car( then goes out). I've read something else about Fuse 15 under the dash??? Given your experience and what I've said are you leaning to bad connections?
Old Nov 10, 2015 | 05:57 AM
I assume its safe to say the light is working because I see the light when I turn the car on.
Correct.
What CEL codes are thrown?
Doing what I said in post #2 is the first place to start, and is relatively easy to do.
Old Nov 10, 2015 | 05:58 AM
tony_2018's Avatar
Fish Twig
Lets not jump all over the place, find a dmm.
Old Nov 10, 2015 | 06:01 AM
BLKOUT23's Avatar
I have a DMM that I can check with.
Old Nov 10, 2015 | 06:03 AM
BLKOUT23's Avatar
Originally Posted by RonJ
Correct.
I had the CEL checked last week and it was P0420 and P0430 not related I believe.
Old Nov 10, 2015 | 06:30 AM
Given that the charging light works and cat codes are not associated with the fuse 15 TSB, start with post #2.
Old Nov 10, 2015 | 06:41 AM
BLKOUT23's Avatar
Thanks for the help. I'll clean and tighten all my connections and then check the reading with my DMM.
Old Nov 10, 2015 | 09:06 AM
BLKOUT23's Avatar
I'm not a complete moron so I came home at lunch and ran some test. The battery had a good 11.9v the car started and it still had 11.9v so I know the alternator is not putting out the charge(14v) like needed. I checked the connection on the alternator and I swear to you it's like some put it on hand tight. Tightened it up, ran the test again and now I have the proper charge volts. I believe problem is solved.
Old Nov 10, 2015 | 09:15 AM
tony_2018's Avatar
Fish Twig
loctite i guess.
Old Nov 10, 2015 | 09:19 AM
BLKOUT23's Avatar
Yeah Loctite will be my next step.
Old Nov 10, 2015 | 10:29 AM
The cluster warning should have stayed on with engine running. Did you miss it?
Old Nov 10, 2015 | 10:58 AM
BLKOUT23's Avatar
I never seen it. I did have a 96 civic one time that the alternator died and it never gave me the warning light(light did work). The made it 3 hrs but as soon as the head lights came on it died. I think the connection had to be bad because the nut was really loose.
Old Nov 10, 2015 | 11:08 AM
To kill the engine, the warning light must have come on at some point while driving, but you missed it.
octodigitus
Dec 12, 2012 07:38 PM
Lasky
Apr 2, 2010 06:37 AM
djrubio
Feb 2, 2010 12:30 AM
haggis
Oct 28, 2008 01:11 AM
unclebenwho
Apr 11, 2006 12:19 PM
