carbs exsist for b-series?
Old Nov 5, 2002 | 09:33 PM
ThatRicerDaniel's Avatar
Default carbs exsist for b-series?
just curious because i want to learn carb. is there any carb kits for b-motors?
Old Nov 6, 2002 | 03:12 AM
Phatwhippin_CRX's Avatar
Default Re: carbs exsist for b-series? (NitrousDreamz)
Pretty sure Weber makes a set for it.......
Old Nov 6, 2002 | 07:00 AM
Peters1983's Avatar
toda make a set but they arent cheap I think it was $2500 http://www.todaracing.com
Old Nov 6, 2002 | 07:22 AM
EP3_05's Avatar
Default Re: carbs exsist for b-series? (Peters1983)
I believe toda only makes the sport injection kit otherwise known as individual throttle bodies.
Old Nov 6, 2002 | 08:37 AM
bryant's Avatar
Default Re: carbs exsist for b-series? (91civic)
correctomondo
Old Nov 6, 2002 | 08:40 AM
allmotorEG-SI's Avatar
those are really just high performace fuel injectors. Not so much carbs. Maybe you could find ones that would fit in the engine bay and get a shop to fabricate something to mount them to the engine or modify the engine block to accept them.
Old Nov 6, 2002 | 09:25 AM
spiceisler's Avatar
Twm Induction http://www.twminduction.com/Catalogs/Catalogs-FR.html makes a manifold that would accept their throttle bodies or Webber "DCOE" style carbs that you probably can get from "Fast Freddys" http://www.rotaryracing.com/ff_ind_carbs.htm
Old Nov 6, 2002 | 09:52 AM
90Zcrx's Avatar
If you're going to run carbs you need a vacuum advance distributor which IIRC they dont make for a b-series vtec engine. I know DPR's drag crx used to run carbs way back in the day but it was an ls engine. Either way the ITB setups are NOT carburators, and they require standalone engine management which is so much bling bling when all is said and done that you should probably stay away.
Black R
Aug 24, 2009 02:01 PM
dkim48
May 10, 2003 08:59 PM
akcivic-teg
Dec 5, 2002 09:27 AM
Drag R
Sep 24, 2002 07:12 PM
