Car runs better with more fuel pressure
Hi,
I have been struggling with the Sputtering/hesitation/bogging/rough idle issues since around three months. I have installed an adjustable FPR, If i increase the PSI to 55 with vacuum hose disconnected the car runs perfect and if i set it back to manufacture specs the car starts to runs like crap. Any ideas?
Have you checked the basics?
Compression good?
Pull the injectors and check they are not clogged or carbon fouled.
Verify your fuel pressure gauge is accurate.
Compression good?
fuel filter recently replaced.Compression is good. I haven't checked the injectors yet. The gauge is accurate because i have tried another one.
How do i know that the injectors are clogged? i have tested the resistance only and all of them around 3 Ohms.
What happens when you set it to 38 and leave the hose disconnected ?
Can you make a clear detailed video showing the different configurations and what happens in real time when using each of them ?
Only oil change and fuel filter. It just happened while i was driving.
IntegraType-R
19
Jul 9, 2007 08:10 AM
ITRfaithful
Nov 2, 2003 06:15 PM
Joon525
Sep 8, 2003 11:51 AM
