1999 Honda Accord LX cutting off while driving
Old Nov 7, 2015 | 05:50 AM
Thomas Hall's Avatar
Default 1999 Honda Accord LX cutting off while driving
Hello all,
I have a 1999 Accord LX that sometimes cuts off while I'm driving. I have changed out the ignition switch and basic tune up. Does anyone have any ideas what else I should try?
Thanks
Madipor
Old Nov 8, 2015 | 03:07 PM
tamboo's Avatar
10 Year Member
Default Re: 1999 Honda Accord LX cutting off while driving
Starting Problems
Old Nov 9, 2015 | 11:24 PM
holmesnmanny's Avatar
Pull any and all stored checked engine codes using an obd2 reader.
Old Mar 26, 2016 | 08:14 PM
Hondamcallen's Avatar
, check out this video Honda die on the road.
Old May 19, 2020 | 11:55 AM
Jeremy64's Avatar
Originally Posted by Thomas Hall
Hello all,
Thanks
Madipor
I have the same issue but very random. I am still digging. Changed cap. Rotor,seals in the distributor. Plugs wires and . Ecu, still have the issue. Have not touched fuel system other than egr ports and cover.
Old May 20, 2020 | 09:44 AM
LR Brewer's Avatar
Crank sensor on the way out? Or do they die all at once?
Old May 22, 2020 | 09:01 PM
ag_ghost's Avatar
10 Year Member
Have you checked your VIN on the Honda site for any recalls? The '99 in my sig was the subject of a recall of the ignition switch module that caused this exact issue.
Recall Number
02V120000
Recall Date
05/16/2002
Component
ELECTRICAL SYSTEM:IGNITION:SWITCH
Old May 24, 2020 | 03:45 PM
MAD_MIKE's Avatar
MM Gruppe B
Did you check/change the ignition switch itself?
Old Jun 3, 2020 | 11:19 PM
Jeremy64's Avatar
Hello all,
I have a 1999 Accord LX that sometimes cuts off while I'm driving. I have changed out the ignition switch and basic tune up. Does anyone have any ideas what else I should try?found an eric the car guy video heres the link
https://youtu.be/WX9EF0eOrVs
Thanks
Madipor
Old Jun 16, 2020 | 11:11 AM
topshot-rhit's Avatar
Was this the issue for you? Our 99 LX (230,000 miles) has been doing this for years but has gotten worse the past few months. I was thinking the switch or some other electrical component was likely culprit given the symptoms of how it cuts off. There have been times it's taken 12-15 times to have the car stay running instead of immediately cutting out. I didn't know this was a common problem.
Old Jun 16, 2020 | 12:24 PM
99stockcivic's Avatar
Often it's the ignition switch. You can test it by starting the car, wiggling the key in the switch, and it cuts off.
That seems to be the most common scenario.
Another common thing is for the engine grounds to either get loose or go missing, or get rusted and cause issue. There's one near the front of the car, over by the motor mount or transmission that seems to get broken or missing often enough.
Of course, there's always a distributor going bad or harnesses that are loose in some manner.
Old Jun 17, 2020 | 03:40 AM
Tried it last night and it certainly acts per ETCG's video so have a switch on order now. For whatever reason, my 99 Accord isn't covered under the switch recall they did for this gen.
cerg0417
Jun 2, 2017 07:31 AM
brackejw
Apr 25, 2017 07:48 PM
Mzcountry82
Sep 24, 2015 09:31 AM
