My ARP head stud has arrived.. I need some help to drive this home.
Old Nov 6, 2015 | 10:39 AM
W95civicEXcoupe's Avatar
GDD's Resident Derp
Icon2 My ARP head stud has arrived.. I need some help to drive this home.
Drive home the stud, drive home the car.. It is my plan that, after this hole gets secured with some torque, to then continue engine reassembly, and see the result. Substantial flushing of both coolant and engine.. For now, though, I am focused on the head stud, specifically.
The stud itself arrived late yesterday, and I chronicled my first attempt to drive it in, and the result, here:
I would like to try again to drive it down in there. It seems there is a 5mm hex or allen driver, on either end of ARP's stud. I also ordered the nut and washer.. Yes. I can see how this then "pulls" the head down. Got that.
It appears the hex or allen driver is used to thread it in?
Right now, I am attempting not only to re-locate my 5mm driver, but to devise a way to have it strong enough to not snap off when trying to turn it in, and down.
If I have to, If I HAVE to, I will go out and un-secure the head bolts, and take the head back off.. Then I can smooth the hole from the bottom, and place back the 1 stud/9 bolts. It is my hope that there is one more try I can make, before I do that.
I'm in a focus zone, so.. Is there maybe a better way to get a vertical tool to place in that hex pattern? ARP stud experts and users, how do you do it?
Thank you.
I am also regrouping. Removed the Time-Sert. It didn't want to work..
This thread takes place AFTER my lunch run..
Old Nov 6, 2015 | 10:43 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: My ARP head stud has arrived.. I need some help to drive this home.
Take your head off. You might as well get it cleaned/hot tanked before you go any further.
As far as putting the stud in:
HOW TO REALLY TORQUE ARP HEAD STUDS!!! Straight from ARP - D-series.org
See post 4 /\
Old Nov 6, 2015 | 10:46 AM
GDD's Resident Derp
See post 4 /\
Post 4:
^^ The instructions do, in fact, say to take the head off.
Maybe its stupid to try to get them down through the head..
I can clean up the head I have, because, if the head fails for some reason, I have located another one. I need to see if this one can pass muster, though.
So. What I'm thinking is, that, I should go outside, and unsecure the 9 bolts, it will probably take me about 20 minutes, if that..
Old Nov 6, 2015 | 11:34 AM
tony_2018's Avatar
Fish Twig
It is stupid.
Old Nov 6, 2015 | 11:39 AM
GDD's Resident Derp
The head is off the engine
Old Nov 6, 2015 | 11:45 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
That last part
Old Nov 6, 2015 | 12:17 PM
GDD's Resident Derp
Old Nov 6, 2015 | 12:26 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
You see that bolt in the front of your block? Like mid way down? If you take that out ALL of the fluid in the coolant jacket will come out.
Old Nov 6, 2015 | 12:32 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Oh and all those shavings you blew out....think about that hole they were right in front of...how many more fell down into there...and where that galley leads to....
Old Nov 6, 2015 | 12:33 PM
NotARaCist's Avatar
I never narc'd on nobody!
Well, there goes your piston rings.
Old Nov 6, 2015 | 12:34 PM
GDD's Resident Derp
I still have a little more to go...
I work tonight, so, the head is in a box, all bolts, and I get to probably continue tomorrow.
I think that once I smooth the head hole, the ARP stud can go in.. I must verify it will slide smoothly.
https://www.youtube.com/watch?v=EkAlWCTbBHQ
I will look for it. It's probably right in front of me. Sounds helpful!
I actually was going to take the oil drain bolt off the pan, and pour oil down it.
To flush out the stuff
Why?
Old Nov 6, 2015 | 12:42 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Did you spray your whole head with the copper coating?
Also, if the stud fits through the threaded hole in the head, just leave it as it or else you're going to mess up that hole even more.
Old Nov 6, 2015 | 05:36 PM
eghatch9295's Avatar
Stancetard Hate Monger
needs more copper.
Old Nov 6, 2015 | 05:37 PM
tony_2018's Avatar
Fish Twig
Oh boy.....
Old Nov 6, 2015 | 06:23 PM
Northernlightz's Avatar
Hahahah thanks for the laugh. You may want to relocate where you put the cylinder head and put something absorbent to soak up the oil. You wouldn't want your cat walking on that then licking its paws. Get some boxes from work and put them on the ground and keep everything clean and organized. Don't spill any coolant either and hose it away if you do. Clean the garage and organize your stuff. Makes all the difference.
Old Nov 6, 2015 | 06:50 PM
24TEN's Avatar
PHANTOM MENACE
So you have literally wasted months now and arguably the engine itself over something that many of us have pleaded with you to do and by your own words will take no more than twenty minutes. Good job genius. So what actually changed your mind to make you finally give in and listen to reason?
Old Nov 6, 2015 | 06:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
ARP Head Stud install instructions.
Old Nov 6, 2015 | 07:09 PM
24TEN's Avatar
PHANTOM MENACE
Got it, he won't listen unless it's actually stated in some form of instructions. There's absolutely no reason for me to offer any advice any longer. Good luck W95!! I'll be watching from the sidelines permanently from here on out with my
Old Nov 6, 2015 | 11:25 PM
GDD's Resident Derp
Hey guys. I slept until 11PM, am at work now.. I can check all that was said in the morning.
I might rent a drill to smooth that hole. I think I might be there forever with the file.
Well.. it did become absolutely clear that the stud wasn't going to go in through the head.. the written instructions confirmed that.. so, I realized upon seeing and doing that I had to sacrifice whatever great seal my HG job may have had, to get the engine to seal right.
Yes.
Can post in the morning. Thank you all..
Maybe I can thread the stud UP, from the bottom, and then place it on the block to thread in like a normal one, once the threads to go in the block hole are flush with the bottom. Since it is also the first bolt in the sequence..
Old Nov 7, 2015 | 04:15 AM
tony_2018's Avatar
Fish Twig
Stupid all over again....
Old Nov 7, 2015 | 04:31 AM
GDD's Resident Derp
How.
Soon, I'll attempt getting the stud seated correctly.
https://www.youtube.com/watch?v=a45jaKAVLgc
I am renting a drill.. going to make it a thru hole again.
Now, to figure out how to "torque down" the stud with a hex wrench. If I just make it really tight, dipped in oil..
Old Nov 7, 2015 | 12:37 PM
burnoutboy's Avatar
The Credible Hulk
The only thing you should be using a drill for is to time sert that block before you REALLY **** something up.
I'll even offer you the cheapest possible solution. ONE TIME.
Instead of paying $450 for the honda kit (Timesert PN 7011) Pay me $250 and I'll drive up from Baltimore Sunday OR Monday and do it for you. I already own the kit. The threads on that block ARE fucked up WHEN the HG fails it will be at that stud.
ALSO get hex bits for your torque wrench, dummy LOL
Old Nov 7, 2015 | 01:50 PM
Bently_Coop's Avatar
Steve at Heart
You don't torque down the stud. You torque the nut on the stud. The nut is what apply's the clamping force.
Old Nov 7, 2015 | 03:15 PM
burnoutboy's Avatar
The Credible Hulk
I thought I remembered the directions from APR saying hand tight. BUT it wouldn't hurt anything to torque them to some stupid low setting so they're all seated the same IMO.
This whole time I've been thinking he was drilling the stripped threads out of the block but he's been talking about drilling threads out of the head... which isn't threaded so now I'm really confused. I'm trying to help him via PM but I'll probably end up there on monday LOL
Old Nov 7, 2015 | 03:39 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
He tapped the head when he tapped the block so now that hole in the head is threaded.
