Suspension & Brakes Theory, alignment, spring rates....
Unable to remount the lower control arms
Old Nov 6, 2015 | 09:11 AM
pixelphoto's Avatar
Default Unable to remount the lower control arms
HELP!!!
I was able to pop the front lower ball joints using the magic ratchet-handle-method trick to remove the lower control arms (LCA). But, now I'm unable to reinstall the lac. From the begining:
Jacked up the car and supported it with jack stands. Jacked up the lca and popped the joints. Driver's side ball popped out of ball joint. Ordered Moog replacement. There are three points were the lac mounts. I'm able to make a connection to any of the two points but there is a large gap at the third point. Brute force does not work. Any advise, insight. I'm stuck up the creek without a paddle.
Element 2004
Old Nov 6, 2015 | 10:29 AM
Tyson's Avatar
Default Re: Unable to remount the lower control arms
Pics help. Your choice of words and description is confusing.
Gap? Seized bushing? Pic would be clear...
Old Nov 7, 2015 | 10:30 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
I'm guessing you're trying to re-attach the spindle to the LCA. You probably popped your inner axle joint out of place. I'm guessing this because it is common.
Post a picture.
We'll never hear from you again.
Old Nov 9, 2015 | 06:17 AM
92_civic_eg's Avatar
Old Nov 9, 2015 | 07:14 AM
pixelphoto's Avatar
B serious your suggestion did the trick. You actually read and understood my post. If you every run for president I'll vote for you! You just heard from me.
Thank you, thank you, thank you,
Marvin
Old Nov 9, 2015 | 03:44 PM
B serious's Avatar
Marvin
Lol glad it worked out for you. I'm currently running for president. Lmk.
xChrizcrozzx
38
Dec 9, 2016 10:34 AM
unclematt
12
Jun 2, 2016 04:31 AM
InTheZoneAC
Suspension & Brakes
19
Jan 22, 2014 05:21 AM
knightsef-eg
16
Jan 2, 2010 06:50 AM
stealth89hatch
Oct 6, 2005 08:21 AM
